I HAVE A RICHO AFICIO 650 MECHINE. THIS MECHINE CREATE A PROBLEM AND SHOW IN PROBLEM CODE ERROR 890. PLZ SOLVE THIS PROBLEM N SEND UR SOLUTION.
I AM ON THE MECHINE THEN THIS ERROR SHOW 890.
YOU SOLVED THIS PROBLEM.
THANKS FOR ALL.
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc... Incorrect parameter sent to the HDD controller. First try
reset the software… press the pointand numeral
key simultaneously until automatically it is off the copier, several seconds can
pass, the copier back on automatically. The software will
have been loaded again. If the problem persists it proves with another
hard disk, since the
other possible solutions already are more complicated; these are:
· Software defective · SBICU defective Another
problem that sometimes cause erratic errors in these copiers is that it has
fallen develop in some sensor having caused short circuits that annul to some
times some voltage of the power supply interrupting processes indispensable for
software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can
seem incredible but it is thus. For it
would recommend a deep cleaning of the sectors of the image unit and everything
what is under the development unit.
there soesnt seem to be an error 890 on system but 880 is mlb you could try and go into the service mode by pressing clear yellow button and then press 107 and hold down the stop button.. thsi lets you into the service screen you want copier sp select 5. mode and go to 5-810 sc reset press execute and turn machine off wait and turn back on it coul djust be a signal error for the address book.. good luck A
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is...
(More)
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is narrower, thus its dimensions are not constant.
Among the solutions I have resorted to were:
- ITB (which I cleaned);
- changed the reader unit afterwards;
- checked the mechaism responsible for the drums unit rotation.
None of the above solutions worked.
I would be extremely grateful for any hint or advice.
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this...
(More)
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this was donated to us, and we would like to repair it if possible and monetarily feasible. Please help.
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black...
(More)
error code 05701 on Oce 9600 The machine says optimizing and after churning away prints out a black copy
