Question about Nikon Speedlight SB-800 TTL Flash
Nikon SB - 800 LCD Defect
Using a D200 and a new SB800, I accidentally popped up the built in flash with the SB 800 mounted on the hot shoe. The SB800 LCD went totall black, showing all black, and it can be read only from way far left or right, a little.
The flash continues to operate normally, but the LCD is black and dead.
Any ideas ? Is this a camera problem, or thks. new flash was defective ?
Thanks.
  • 62 Answers
Impact has damaged the LCD assembly .
IF you want it repaired contact the email address below
Berrie Smith Camera Repair
bbmw@bellsouth.net
Posted on Feb 06, 2008
I am using a nikon D200 with a sb800. The flash is firing ok on TTL and the camera is set on 'P' however I am getting a dark picture every tme. The built in flash works OK It appears the flash/camera...
This is an excellent flash, very powerful and compact and actually more flash then what was available when the D200 first cam on the market. The two will work nicely together and I think the problem is that the SB-800 can be programmed within itself. This meaning with some cameras you program the camera for the flash output with the SB-800 you can program the flash as well. It has some excellent features like Flash value lock (which I think is set to slightly underexpose from what your question is asking) it also has Flash color information and a built in Flash compensation. Possibly the compensation or value lock are set to underexposure. I'm saying this over the camera setting because you stated that the internal flash appeared to be okay, check your SB-800 settings
Dec 27, 2010 | Nikon Speedlight SB-800 TTL Flash
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb800 firing without pressing shutter release
sounds like a short in one of the circuit boards, most likely one or seveal of the ribbons and boards will need to be replaced to correct the problem. Send in for repair expect to pay up to $200 for a Nikon factory overhaul
Feb 21, 2010 | Nikon Speedlight SB-800 TTL Flash
SB 800 Speedlight AF red lamp not function
The problem is probably caused by a fault in the main power circuit board, if the red light doesn't come on then you also probably won't hear the high pitched noise as the capacitor charges. Will be expensive to repair as you will need a new circuit board.
Aug 16, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikon SB 800 fires but pictures reamain dark
I have 2 SB-800s. When batteries leaked in one Nikon took forever to fix it, so they eventually sent me a refurb. Then they sent my original back. Which was great, until recently it developed this problem.
Another possibly related side effect is the modeling flash does not burst -- it only fires a single (very bright) flash.
The capacitor argument sounds likely. Coincidentally I also had a problem where the flash would fire sporadically -- but that was due to scuz buildup on the contacts.
Sorry I don't have a real solution for you.
May 27, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikon D3 and SB800 flash problem
The Sb800 and the Sb900 is compatible . Can you tell me more of what the problem is .
There is no frim ware for the flash . The NIKON SB 900 FLASH SHOE IS THICKER AND MAKES BETTER CONTACT . THE NIKON SB800 SHOE IS LOOSER AND NEEDS TO BE ADJUSTED
Nov 23, 2008 | Nikon Speedlight SB-800 TTL Flash
Unwanted flash fire in nikonD200
Hi, I had the same sort of problem. It started with erratic small flashes but then evolved to the SB-800 not regonizing the D200 at all. The result of this is that I only get TTL and not TTL+BL+FP functionallity.
To solve this I cleaned the hotshoe on the D200 with all purpose cleaner for electical appliances (CRC 5-56). This gave minor improvment. Then I adjusted the spings to the left and right on the hotshoe on the D200 to press harder against the flash's connection (which I suppose is the grounding). Now everything works again.
Best regards,
Marcus
Jun 21, 2008 | Nikon D200 Body Only Digital Camera
Zoom range 14-17mm
make sure the diffusion dome and the built in wide angle adaptor are off. If the diffusion dome is on, it will only work as 14mm and 17mm without the diffuser but with the wide angle panel.
May 10, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
435 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
