Question about Linksys WRT160N Wireless Router
Cant connect to the internet with linksys wrt160nv2
I have a linksys wrt160n v2 and i cant manage to connect to the internet. when i connect the modem directly the internet connection works fine, but when i connect the router, my pc cant get any internet connection.
i allready tried both DHCP and manually configured ip with the same dns and gateway ip's (192.168.2.1) my router ip is also (192.168.2.1).
i can get to the router settings (change password,etc), but still no internet.
can anyone help.thanks
  • 22 Answers
If this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Posted on Jun 12, 2009
I recently had the same problem and contacted Linksys for help. They advised that they were aware of a problem and that I needed to download a different firmware version to correct. There are instructions on their site to complete a firmware upgrade if you are having problems connecting to the internet.
Posted on Jun 27, 2009
SOURCE:
How do I turn on my upnp for my linksys wrt160nv2
UPnP aka Universal Plug and Play
Universal Plug and Play allows Windows to automatically configure the Router for various Internet applications.
If you want to use UPnP, keep the default setting Enabled. Otherwise, select Disabled.
Click here for the pdf manual... http://belkashop.com.ua/products_files/WRT160N_ug.pdf
Feb 20, 2011 | Linksys WRT160N Wireless Router
Hi I configured wrt160n v2 linksys router well but when the power goes down and restart it again it stop working for more than 1 hr? any solution for it? Noor Muhammad ISP Engineer Multinet Kabul...
your ISP is a cable or DSL...??? if it is a cable then you should do a mac clone... if your ISP is dsl, then check with the direct connection from modem....Make sure the direct connection with modem is working good when the modem is restarted and connect the router...
Aug 10, 2010 | Linksys WRT160N Wireless Router
Trend Micro Firewall interfering with WRT160Nv2 router
You will have to uninstall the trend mIcro and can install a free free program like avg.
Jun 09, 2009 | Linksys WRT160N Wireless Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
LInksys wrt160n v2 wireless router not connecting to internet
Most cable companies will only allow 1 active device at a time conneceted to the cable modem. When ever you change what is connected to the cable modem you must always cycle the power/reset your cable modem.
When you are reseting the units, always rset the cable modem first, wait until it boots back up then reset the router. If that doesn't fix the poblem then it may be a configuration problem.
I forgot to ask if you are cable or DSL.
Hope this helps
Apr 09, 2009 | Linksys WRT160N Wireless Router
Router not connecting to internet modem
This is a tuff router.  I bought it myself hoping for good things, and spent a good two days actually getting the thing to work.
I got mine to work by plugging it into the modem, the laptop I was setting it up with, etc, and then running it all. I would just suggest trying to reinstall it again with everything plugged in from the get go, and then hope for the best.... sorry I cant help more.
Jan 27, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N Wireless Router  Logo
4,545 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
