Question about Compaq Presario R3000 Notebook
CPU fan operates but laptop otherwise dead ?
I've got a Compaq presario R3000 that's been giving me power problems. When connecting the external power to the port on the laptop it seems loose and the icon for power goes from "lead" to "battery" until the lead is "fiddled" with until the "Lead" icon returns. However, the laptop now simply switchs on with only the CPU fan working but no display and no boot sequence. The battety is virtually fully discharged yet when you remove the external power the laptop doesn't completely die and switch off which suggest there is enough juice in the battery to run the CPU fan but not enough to activiate the boot sequence ? I've removed the cover to the power mechanism and noticed a split in the silver covering to the external power port - could this be the problem ?
  • andervid May 15, 2009
    I have similar problem. But I tried turning on for several minutes and the fan continues to run...meaning there's enough power to supposedly turn my laptop on. However, I see no POST nor video nor sound. Although the power indicator remains lit with orange color. Would someone help me please!!!!
  • 90 Answers
Remove the battery and plug in the power adapter. Attempt to power on the laptop. If nothing happens, then try holding the power cord, at the jack, at a different angle. Wiggle it a little and see if the laptop will come on. If it does come on, then wiggle it some more and see if the laptop cuts off.
This will determine if your DC Jack is faulty. I have resoldered a bunch of these on this model. Usually the solder around the HOT pin on the mainboard cracks. Thus, you don't get a good power connection.
Now, as far as the laptop coming on with the battery.... how long will it run on just the battery? A couple seconds? Or a couple minutes? Or until you turn it off? If the battery were about dead, then it would come on for just a couple seconds but not POST. Meaning no video or anything. But if it comes on and runs for several minutes without turning off, then a weak battery isn't the problem. It should still POST and show video and all that.
So, even if you get the DC Jack fixed, assuming its faulty, this may or may not solve your POST problem. Never know really until the dc jack is for sure supplying good steady power.
Posted on Oct 29, 2007
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
Compaq presario fan stopping
Take it back to the place of purchase since it is under warranty, otherwise you will damage the processor which the cooling fan protects.
May 03, 2012 | HP Compaq Presario V2310us Notebook Pc...
I have a presario R3000 notebook. just like to ask if the fan for ventilation underneath is working in a certain temperature. or it will automatimatically running when i plug in.. can some one help me....
There are several models of this notebook depending on the processor. Some only have one fan, otehrshave two. When operating the fan should start running. I have the higher spec R3000 and my fans start soon after the machine is turned on and sometimes throttle down if I have no activity. Upon starting to use it, they soon start again. Considerable hot air will come out the right back and side.
DO NOT block the air intake(s) on the bottom of the unit !!! You can burn up the processor.
Sep 25, 2009 | Compaq Presario R3000 Notebook
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Compaq Persario R3000
i have a problem can you please send me a atachment of this driver base system device so i can instal it to my laptop compaq presario r3000
my email is
Sep 04, 2008 | Compaq Presario R3000 Notebook
I have a compaq presario R3000
connect a monitor to it first, maybe your screen is dead if your money still doesn't show anything then u gonna need some memory
Jul 05, 2008 | Compaq Presario V4000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
My monitor isn't working
maybe the problem is connection cable between monitor n cpu, try to open n close your monitor. then try on again, if not u have to bring service center
Aug 14, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
