Home | HP | Digital Projector Vp6120 Multimedia Pro... | Projector turns on the...
HP Digital Projector Vp6120 Multimedia Projector
Problem for HP Digital Projector Vp6120 Multimedia Projector
Projector turns on the power light flashing and lamp light solid
By sammo604 on Jun 12, 2009
unit turns on fine te the bulb turns off and as described above power light flashes and bulm light stays solid checked all fans
Best Solution
posted on Jun 23, 2009
Helpful)
sabharish
Rank: Guru
Rating: 85%, 232 votes
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP Digital Projector Vp6120
Questions and Unsolved Problems for HP Digital Projector Vp6120
Do you recommend HP Digital Projector Vp6120 Multimedia Projector?
Answer
Answer
hp vp6120 finds video but does not find laptop Have extended image onto hp but is not finding any... (More)
Answer
The red "wrench" is lit on top. The blue power light goes off. Is it the bulb?
Answer
seems i have the same problem with my hp vp6120 - lamp replaced (i have tried 3 spares so confident... (More)
Answer
i'm having a problem finding a replacement bulb for my HP vp6120. Philips lamp, type #UHP 250W,... (More)
Answer
hp 6120 cant seem to get rid of the red /blue or mauve colours.we have tried to adjust to either end... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Digital Projector Vp6120...:
Top Multimedia Projector Experts
Rank: Guru Guru
Solutions: 1178
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Multimedia Projector Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
