Question about Canon i9900 InkJet Photo Printer
How to clean canon 9900 printhead - Canon i9900 InkJet Photo Printer
I have a i9900 printer and it is printing on th magenta side
It is a possibility that your other colors are empty. It can also be that you need to clean other printheads, if no ink is coming out. Try an automatic cleaning of the printhead. it is in your manual how to do that.
Nov 11, 2011 | Office Equipment & Supplies
How to clean a printhead for canon pixma MP540 . i have used the deep clean but no help
Deep clean should clean the printhead, but it's an expensive way to do it, since a lot of ink is used.
Do you have lines of non printable areas? Maybe replacing the printhead will help.
May be out of ink in certain nozzles on the printhead.
Oct 19, 2010 | Canon Office Equipment & Supplies
I have a canon i960 printer. It won't print blue. All other colors work fine. I've replaced the ink, downloaded new drivers, run the clean print head utilities, both regular and deep cleaning. What do...
I would guess that the printhead is bad. Google cleaning printheads or get a new one. Sometimes , not always you can clean the printhead instead of replacing. (take out and clean by hand)
Apr 07, 2010 | Canon I960 InkJet Photo Printer
Cannot clear clean printhead message on Canon IPF 710
Assuming you have cleaned/serviced the printheads correctly?
And have run the printhead cleaning software providided (if any) by the manufacturer of the printer?
Nov 16, 2009 | Canon imagePROGRAF IPF710 Printer
My printer Canon MP760 does not print black.
Your black ink must be empty replace with a new one and print.
Sep 20, 2009 | Office Equipment & Supplies
My canon i90 printer wont print. it appears to working perfect but the result is a blank paper. i have installed new cartiages & run all maintenance functions.
It sounds like the printhead is plugged, but there is also a firmware upgrade that helps position the printhead for better cleaning, Canon suggests you try deep cleaning 3 times in printer maint. from the properties menu before replacing the printhead. I use a syringe to put a couple drops of water on the cleaning pads on the right to help with cleaning.
Aug 31, 2009 | Canon PIXMA iP90 Mobile Printer
CanonI9900 will not print correct colors
The 9900 is a great printer, some parts wear out tho, There's a membrane in the printhead that goes out allowing cross contamination of the inks. You would need to replace the printhead, sometimes also the hoses can come off of the clean and purge assembly so that the printhead is not primed properly. That would be a shop repair. You should let a shop check it out for you, could save money and time...
Aug 16, 2009 | Canon PIXMA iP1600 Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer doesn't pring
Try cleaning the printheads
Performing the printhead cleaning procedure
  1. Power on your printer, press and hold the "RESUME" button until the printer light flashes once.Note: You can also clean the printhead by clicking the Cleaning button in the Maintenance tab of the printer properties dialog box in Windows; or clicking Cleaning pull-down menu in the Printer Utilities dialog box on a Macintosh computer. Choosing this option will allow you to select all nozzles, black or just the colour nozzles.
  2. Pressing Resume on the printer will clean all nozzles. When the printhead cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.3. Perform the Nozzle Check Pattern test again
  3. If the results are satisfactory, resume normal printing
  4. If the results are not satisfactory, you may need to execute a printhead deep cleaning.
Deep printhead cleaning from the operation panel
  1. To deep clean the printhead from the operation panel
  2. Press the Maintenance button.
  3. Press the Right Arrow button three times.
  4. Press the Print button. Printhead deep cleaning starts.
  5. When deep head cleaning ends, press the Maintenance button to exit.
Deep printhead cleaning in Windows
  1. Make sure the printer is turned on.
  2. Click Start, then Settings, then Printers.
    Note:Windows XP users: Click Start, select Control Panel, then Printers and Other Hardware, then Printers and Faxes.
  3. Right-click the Canon S820D Bubble Jet printer icon, then select Properties.
  4. Click the Maintenance tab, then click the Cleaning or Deep Cleaning button. The Maintenance tab and procedures may vary for Windows 2000 and Windows XP. Follow the instructions when prompted for those operating systems.
  5. For each message displayed, click OK. The BJ Status Monitor opens automatically and closes when the printhead cleaning is done. The POWER lamp on the printer flashes green during the cleaning process.
May 18, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i9900 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
