It work with safe mode that it
Put you operating system again
or
buy a password recovery program to brake the password
is it a bios password or a operating system password ? if it is bios, can you pull the battery out ? if you can pull it and leave it out without power for about 30 minutes, that should force it back to factory and allow you in, if it is operating system, you either have to purchase a password reset program, or re-load the OS
SOURCE: gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
SOURCE: i am working on my friends gateway mx6450 laptop
1. Refresh the screen: Right-click on the desktop and select [refresh]
The icons will appear.
if not,
Boot to the Safe Mode screen and select "Start in Last Known Good Setting"
SOURCE: don't remember password on bios of a gateway solo
Simplest is to remove the battery for a while so the password is lost.
See the TechRepublic article at
http://articles.techrepublic.com.com/5100-10878_11-1032878.html
SOURCE: cant remember administrator password
If you are running Windows XP Home, you can boot into safe mode, and then reset the password on the user account you are locked out of.
SOURCE: I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
