Question about Kensington in a Box Optical (DH72123) Mouse
Left clicker doing odd things
My left clicker is doing weird things. Most of the time, when I push it it doesn't register. In order to get it to do so I have to hit it very hard towards the bottom of the button.
Meanwhile, it registers at odd times, causing me to jump around a page of text mid-word! It also seems to be 'holding down' the button, as when I try to move it it wants to highlight everything I move it over.
Any ideas?
The click-lock was not on, by the way. I also tried uninstalling the device which didn't help at all, either.
  • 749 Answers
Hi... If the mouse is somewhat used for a long time since it was bought, I usually check the mouse cable. Sometimes, when the cable is stressed out especially the line near the clicks/buttons, it's not totally cut-off yet, Try opening the mouse and try one by one pulling the colored wires inside the cable... you should be able to pull at least one line which caused the problem... If there is then you need to connect it back... you need a little help from an electronic technician guy... but if you are... well... you know what I mean...
Posted on Oct 29, 2007
  • Rommel Balcita Oct 30, 2007
    Ok.. so wires are good... try a tester to test the continuity of the button... If you click it, the tester should react. If not then you need to change that button... scrap it from an old mouse for that part.
  • Patrick H
    Patrick H Jan 25, 2014
    But, tinkering with my cable seems to do nothing. Might it be old and stressed?
When i hit right on the D pad it moves left how do i fix it?
DIY Fix the d-pad on the Xbox 360 control pad (more than just
www.instructables.com/.../DIY-Fix-the-d-pad-on-the-Xbox-...
InstructablesOkay, first things first: I find the d-pad on the 360 wireless controller to be a mushy mess. ... hits the contacts on the circuit board) and the bottom of the d-pad's contact ... All we're going to do is add a very thin layer between the membrane and the ... controllers, pressing right will for example register as down-right, and so on.
Weird Controller Glitch - Left on Analog is Right on the D-Pad
Dec 25, 2015 | Computers & Internet
My left clicker button has stopped working?
Yes, the switch part can fail. Repairing the motherboard can be labor intensive and costly. U might just want to consider using a usb mouse to work around the issue.
Mar 12, 2015 | Acer Aspire 5734z-4836 Laptop
Samsung p510 left clicker isn't responsive. I am having to double tap the touchpad in the mean time. What is this part called on a laptop?
The left button, buy a can of compressed air attach straw and lift left button with fingernail gently, now give a few good blasts to clear out any dirt that might be obstructing the pad underneath the button, repeat if needed.
Apr 15, 2012 | Samsung N Computers & Internet
My dell laptop sensor pad is not responding all the time can you help
Buy a can of compressed air, attach straw, slightly lift left clicker with finger nail and give good blast of air in the crevice, "few times" repeat with right clicker, this will clean out any dirt and hopefully fix the problem.
Mar 31, 2012 | Dell Computers & Internet
Baygenie problem with daylight saving time and no bid.
you might try changing the time on your computer to compensate it
if only for a short time
hope it helps
Dec 25, 2011 | Computers & Internet
The left button at the bottom of my touch pad has a problem. the click is delayed, i have got to hold the click for longer so that the click may occur
@inam_khan_10
Try the following:
1. If your computer is running on Windows, try to boot into Safe Mode (you need to press F8 continuously upon boot-up then choose Safe Mode) and check if your Touchpad left clicker. If it works ok, then a software problem is causing the Touchpad to delay like that. Try reading this guide to solve it.
2. If Step 1 above doesn't work, try to use a compressed can of air to clean the Touchpad clicker and see if same issue occurs.
If still no go, this is a sign that your Touchpad is already wearing out and it needs to be replaced.
Good luck.
Sep 05, 2011 | Computers & Internet
1982 Suzuki GS 1100 GK, Need to know the cyl numbering order and if it is right to left or left to right.
firing order
1342
coils are odds and evens 1,3 and 2,4 firing together as a waisted spark looking at exhaust ports 1 is on the left side next to the ignition timing cover
Aug 18, 2011 | 1983 Suzuki GSX 1100 E
Hi, my left clicker on my Sony Vaio stopped working. The right clicker works as well as the scroll pad but clicking on the scroll pad doesn't work as well. I have tried rebooting, installing the mouse...
More then likely the button has worn out.The first thing I would try to check to see if its the button or not ,just plug a mouse in to the laptop and see if that works with left click if it does it just may need a new button put in.If your handy you may even be able to do it yourself.If you have any other questions just let me know.
Jun 11, 2011 | Computers & Internet
How to fix jammed clicker on air rifle scope
Sorry to tell you but the crosshair adjustment is more than likely broken. Take it to a qualified gunsmith and he can check it out for you.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks.
Jan 12, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Kensington in a Box Optical (DH72123) Mouse Logo
74 people viewed this question
Top Kensington Computers & Internet Experts
Alun Cox
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
