Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Water Dispenser and Ice Maker
Guys,
You have more or less answered this before but here goes.
My water was coming out slower and slower then stopped completely before that the ice maker stopped making ice as no water was getting to it.
the water filter light has never come on and I know water is getting to the fridge.
I have removed the water filter and when I shake it something heavy moves around inside, is this normal.  My fridge and freezer are very low on produce so could the lines have frozen up and if so what steps should I take.
  • Anonymous Jul 15, 2008
    filter shows red will it stop ice working
    Scholar:
  • 146 Answers
Have you checked the pressure limiting valve which protects the filter from over pressure? It could be blocked/faulty. Have you checked the inlet on the valve assembly? It may be clogged up. Try bypassing the filter all together to determine if the filter is faulty.
Posted on Oct 30, 2007
SOURCE:
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
Water not stopping coming out of the ice maker
Nov 05, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water to ice maker does not shut off after filling tray
Sep 03, 2009 | Maytag PSD2450G Side by Side Refrigerator
My jenn air freezer is not making cubes. the
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
ED5LHAXMQ00 SP3242185 THE ICE MAKER WILL NOT SHUT OFF WHEN FULL
Jul 12, 2009 | Refrigerators
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
150 people viewed this question
Top Admiral Refrigerators Experts
Jose Pino
steyr1
Bruce Denton
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
