My switches and fuses are ok but the massage is still on, can it be anything different then this 2
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
SOURCE: Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
SOURCE: Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
SOURCE: kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure
Code
F0 - E0
Analog to
Digital Failure
Disconnect
for 30 seconds - if display re-appears - replace control
F1 - E1
Safety flip
flop
Replace Electronic
Range Control/Clock(ERC)
F2 - E0
Shorted keypad
Replace Electronic
F3 - E0
Oven temperature
sensor or oven temperature sensor fuse opened
Replace oven
temperature sensor or fuse
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
F3 - E2
Oven too hot
Replace oven
temperature sensor
F3 - E3
Clean temp
too hot
Replace oven
temperature sensor
F5 - E0 F5
- E1 and E2
Check door/latch
switch
Replace component
2 Digit Failure
Code
F0 or F1 or
F5
Failed transistor
Replace Electronic
F2 - E0
Oven temp
too high
1. Test
operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
F3
Thanks
