Yesterday, I noticed that my bluetooth wouldn't turn on or off. After plugging it into the charger, the light would go on and it would charge. When it was unplugged from the charger, the light would remain on; and if I manually tell my phone to connect to the bluetooth, it would, and the device would work well; however, I could not turn it off. I would have to manually tell my phone to disconnect. (Note, later on, the only way to connect my phone was to first plug it into my charger, and connect when the light was still on) Now as of today, the device doesn't work altogether. Tried charging it get it to connect, but no luck. Power button doesn't turn it on nor off. I see the light go on when it charges, but turns off when I unplug it. Any way to reset it?
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
