Question about Technics SL-BD22 Turntable
Playing speed HiDusted down some of my old LPs and put them on the turntable. Unfortunately the playing speed varies at it is difficult to get the strobe to remain constant. Any ideas, worth fixing or better to buy a new one?
  • si111 Oct 29, 2007
    It's a technics SL-BD22.
Just use some contact spray on the pitch adjustment reostat.
You may have to remove the bottom cover to reveal the mechanism. After the spraying turn 2-3 times the reostat left and right and you 're ready to go.
I hope that this tip solves the problem. Anyway in my case worked.
Dimitris from Greece
Posted on Mar 21, 2008
    Novelist:
    Champion:
  • 382 Answers
Whats the model?
Posted on Oct 29, 2007
SOURCE:
33 Records are playing a bit too fast on my Wockoder Record Player... Is there any way to fix this?
Lots of quality turntables have a speed checker and a limited amount of speed adjustment.
Many ordinary record decks use a synchronous motor, the speed of which is regulated by the Hz of the mains supply and with mostly fixed gear ratios it is impossible for them to run faster - slower is the usual problem.
I expect there will be types driven by a dc motor and regulated by a switch mode power supply but I know nothing about them.
I suggest you begin by learning something about your turntable.
Dec 27, 2017 | The Audio Players & Recorders
Turntable speed varies
search for same questions , otherwise we keep typing and too fast sping is also the right search.
Apr 05, 2014 | Technics Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
My audio technica turntable is playing records too fast. how do i fix this?
there are two small holes under the unit labeled 33 and 45 that control speed. im guessing youre mainly playing lps so use a flathead jewlers screw to adjust the 33 setting until you get the right speed
Jan 08, 2011 | Sony PS-LX250H Turntable
VINYL PLAYER SLOWS WHEN I STACK A COUPLE OF LPS sounds funny play fine with just 1
The labels on the LP's stick up higher than the vinyl. These slip on each other when you stack LPs.
One LP sits directly on the turntable mat and has enough friction to turn.
The only solution I can think of is to put something 'tacky' on the labels but this might be detrimental to the label.
Dec 16, 2010 | Audio Players & Recorders
Technics SL-QL15 turntable for the charity shop?
If it still in perfect running condition, An audiophile of LPs should be interested in buying it. I sold my 30 year old Technics SL-1300 mkII for $250
Jul 30, 2009 | Audio Players & Recorders
Technics SL-BD22 Turntable Logo
245 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
