WHERE CAN I FIND A POWER SUPPLY WITH A 5 PRONG PLUG
Try www.driverguide.com
Or the manufacturer of the mother board website.
http://s807.photobucket.com/home/budm/allalbums
SOURCE: Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
SOURCE: damaged power cord
The power supply AC adapter power cord is the same as used for PC power cord, local PC repair shop should have them.
Or you are looking for the AC adapter is 12v 4A power adapter, try Ebay
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Testimonial: "Thank you very much! Very helpful!"
SOURCE: SVA VR-17s, I inadvertantly reversed
It difficult to say what thing or things got damaged when they are reversed biased. If you are lucky it could just be a fuse, otherwise there could be a lot of components that could be damaged by the reversal. Only way to know the extend of the damage is to pop open the case and look inside. I would check if it has a fuse first and the condition of it and look for any obvious parts that were blown up. Unless you know how to troubleshoot electronics, it not worth the trouble to try to see if you can fix it considering how affordable LCD monitors have gotten.
SOURCE: USER Manual For Need a SVA VR-17B LCD Monitor
Did you try their web site? http://www.sva-usa.com/ Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
This is 2005 model so it will be real hard or impossible to get.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Basic LCD monitor and LCD TV troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
