Visit the SmartThings Find website. If you have a Samsung tablet that is signed in with your Samsung account and has Remote controls enabled, you can use ...
2.
Sign in with your Samsung account. You must be signed in on your tablet with a Samsung device, which you were prompted to create when you set up your tablet ...
3.
Click Unlock. You'll see this with the icon of an open lock pad on the right side of the website.
Create a new Google account. Something happened to the old account, easiest to just create a new one. You might be able to reuse your old account name to make a new one.
this would be in mail settings in phone settings - account properties
. POP Server or
IMAP Server Authenication required.
user name and password needed.
2 Charge the device. Prior to turning on the Galaxy Tab
, plug it into a wall outlet using the supplied power adapter.Hold
down the power button for a few seconds to turn the tablet on.
Let the Galaxy Tab charge fully before disconnecting the power adapter.
3. Follow the on-screen prompts to select language, network, and location settings. We recommend leaving location services on.
Turn Use network-provided time on and select the appropriate time zone. If you are prompted to sign in with a Samsung account, tap
Skip in the lower right. Sign in with the Google account you'd like to use with this device. Uncheck each of the 'Backup and restore' options. Note: Icons may vary from device to device, but shoul
d look close to what you'll see below.
4. Install apps using Google Play From your home screen, tap
the Play Store icon: If prompted to 'add an account', select Yes
and then sign in with your Google account. Install OverDrive Media Console(OMC):
a Search for 'OverDrive' in the search bar in the top - right - corner of the screen.
b. Tap OverDrive Media Console then follow the prompts to complete the installation.
good luck.
It's a windows 7 server error and thus most likely the fault of the web site in question. It's failing to verify your log-in. You may have to remove your gmail account log-in from the tablet.
Try going Settings>Accounts>Google>Tap your account> tap three dots in the upper right (or press menu button) "Remove Account".
Go to "Settings"->"Applications"->"Manage Applications"
Select "All"
Scroll to and tap "Google Play Store"
Tap "Force Stop", tap "OK", tap "Clear data", and tap "OK".
Tap the Back button to get back to the applications list.
Scroll to and tap "Google Service Framework" (or Google Play Services)
hey...i have never had such a problem with my tab but the same thing was happening to my galaxy phone..so i created a new account using my laptop, switched off my phone for a couple minutes then when it was on, i signed in using the account i had created on my laptop and it worked..try it on your tablet, hope it works.
For your tablet, to get Yahoo! mail you have to activate POP setting; to activate pop on your Yahoo!Mail account you have to pay for it. Now, if you once signed up for Yahoo! Mail Plus, add a new email account
to your email program with the following POP and SMTP settings:
1. Yahoo! Mail POP server: plus.pop.mail.yahoo.com 2. POP port: 995 3. POP TLS/SSL: yes 4. POP user name: your Yahoo! ID 5. password: your password
1. Yahoo! Mail SMTP server: plus.smtp.mail.yahoo.com 2. SMTP port: 465 3. SMTP TLS/SSL: yes 4. SMTP user name: your ID 5. SMTP password: your password
In case you will have some errors/problems having such settings you have to:
# Log in to Yahoo! Mail # select OPTIONS > MAIL OPTIONS > go to POP/FORWARDING > choose VIEW POP on Yahoo!Mail Server.
