Question about Prestige Remote Start
Prestige APS2K4SAW LED constantly on, remote start not working
My remote start used to work great for a long time, then I noticed that the LED is constantly on and the buttons stopped working. I replaced the battery and the remote start work again I assumed this fixed the problem but the led light is still on, then the next morning the remote would not start the car and the batter is brand new from the night before. Could the FOB be stuck in valet if thats possible? or what does the led being on constantly mean?
  • 1 more comment
  • mikey_gy2 Mar 04, 2014
    Ive had no work done to this car in regards to the remote start or anything that would need someone to mess with any system involved. the remote start worked when a new battery was placed in the KEY FOB then over night, im not sure what changed but the LED did not shut off on the fob and the car wouldnt start but it did the night before when the battery was replaced.
  • Billy Mac Dec 01, 2017
    The remote has an internal short on the microprocessor IC chip, it could also be corrosion on the board but I have seen these remotes short out when I used to install these years ago, it will kill the battery overnight
    The remote has value even broken for parts, dont throw it away sell it online !
    New Friend:
  • 36 Answers
Yes i think it might be in valet
Posted on Dec 14, 2017
4 Suggested Answers
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
  • 19 Answers
SOURCE: I have a prestige APS2K4SAW remote and it just
for a programming guide to reprogram it we offer it for free in our website's forum at www.lesscoelectronics.com if you need more help we also offer free live chat there as well. Good luck!
Posted on Jul 29, 2010
richroth
  • 9472 Answers
SOURCE: I have a PR00E4BS 4-button
Here is a link to the programming guide for the remote Here is a link to the manual Here is a link to the installation guide
Happy Holidays
Posted on Dec 12, 2010
Remote starter not working elvatoe APS2K4SAW
Factory remote start or aftermarket ? What the hech is this elvatoe APS2K4SAW.If it isn't factory , get it out of there .
Feb 23, 2015 | 1997 Pontiac Sunfire
I have a prestige APS2K4SAW REMOTE START, i have this problem when i have a key replacement coz i lost both of my keys..the lock and unlock button work fine but remote start won't work..the engine seems...
Sounds like you may have a smart key with a transponder. The car will crank with a differant key but will not start because fuel and spark are dissabled. A new key is required and it must be coded to the vehicle by the deaker or a professional with the appropriate software. Then then a copy of the key is usually placed in a 555 box that is located close to the ignition switch so the transponder will still work. So basically you will need two keys made and coded.
Feb 16, 2014 | Prestige Remote Start
Key fob light stays on wont work
A guy I work with has the same prob from time to time he takes the fob to the dealer and they reset it or somthing
Dec 14, 2013 | Prestige Remote Start
Car shuts off...
After starting the car with the remote, when you get inside the car. Make sure you are putting the key to the on position BEFORE pressing the brake pedal. If this doesn't help please let us know the type of car you have.
Nov 04, 2013 | Audiovox APS901 Car Prestige Remote Start
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
I have a prestige APS2K4SAW remote and it just quit working, how can I fix it please????
Jul 01, 2010 | Car APS25CH Prestige 2 Button Remote...
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Astra remote car starter problem
your remote starter is in valet mode, the door lock will still work but no remote start, try pressing the trunk button 3 times, if that doesn't work turn the ignition switch on and off 5 times
Jan 03, 2010 | Astra Car Alarm And Remote Starter,...
Prestige Remote Start Logo
445 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
