Question about LG RH177 DVD Recorder/HDD Recorder
DVD locked in and door is not opened
Hi There
After finalizing the DVD, I just get "Please, Wait" on the front panel and DVD recorder door is not openeing at all.
According to the noise from DVD recorder it seems that DVD keeps stop and start rotating.
Tried:
1) Eject butoon on the remote control and on the DVD recorder to open the door
2)unplugged overnight
3)Reset the device by pressing power button longer than 5 seconds(no changes noticed in resetting)
none of the above worked, please advise me what to do.
Thanks
Soheil
  • Roxanne2 Nov 21, 2007
    My DVD Recorder is a Philips DVD Recorder 3440H.
    It works fine until I press and hold down the stop button to open the draw, then I get a message on the display which says BLOCKED, and the draw just won't open. I have tried unplugging the machine overnight to restart it up next morning, but still the draw just won't open. I have only had the recorder a few months, but cannot find the receipt to take it back to the store, and I cannot remember if I bought it from Curry's or Dixon's.
  • rozimozi80 Dec 02, 2007
    we just bought lg rh177, but when we wanted to start it, it just write "please wait" and nothing happening. we can not open it to take a dvd and nothing is working.
    Problem Solver:
  • 7 Answers
For those users who just bought their machines, I would suggest warranty service. Roxanne2 should contact Philips directly with the seiral number, and they should be able to say which store they sold it to. That unit probably has a bad internal DVD writer drive.
The following solution should only be done if your machine is out of warranty unless you get permission from the manufacturer, as it will likely void the warranty otherwise:
Unplug the unit, disconnect all cables and move it to as static-free of an area as possible. Remove the cover, which usually means removing a lot of screws. Most DVD recorders have regular drives like you see in PCs. There is usually a tiny hole in the lower-right part of the drive that you can stick a small wire into, such as an unbent paper clip. You can then manually pull the drive open to get the DVD out.
Posted on Dec 08, 2007
How do I unlock my dvd HDC 300 recorder?? The door does not open and says Locked
If you have the manual it should say something about a child lock
Oct 20, 2014 | Sony RDR-GX300 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Hi there, My problem is I have a toppro tpr2000 hd recorder and sometimes when I record and have finished, and press stop I get 'record is finalizing please wait' which then just freezes on the screen....
It won't damage the recording on your recorder it will mean you won't be able to view the disc on a different machine, possibly. The finalizing of a disc ensures the table of contents is recorded on the disc.
Try a better quality disc?
Feb 07, 2011 | Televison & Video
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Fanalize in Panasonic DVD Recorder failed
Hi,you need to have the laser replaced in the unit.
Aug 24, 2009 | Televison & Video
DVD disk tray will not open at all
had the same problem the mechanism for the door opener is faulty.........waited for 2 months to be finally told by samsung part is no longer available......wonderful back up service isnt it. Luck have it I had an extended warranty and getting it replaced with a LG combo
Jun 03, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Just comes up with "Please wait" it wont load!
I had a RH 178 with the same problem. I opened case and removed the plate with the 2 drive cables and the front lcd cable. Simply wait a few mins and plug it back in, connect the 3 cables and use the 4 srews and VOILA it runs!!
No more "please Wait"
I think it was a connection problem with the "uplink" to mainboard (not the three drive cables and LCD). Can someone please report if it works with his LG?
greets proliant
Aug 02, 2008 | LG RH177 DVD Recorder/HDD Recorder
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG DR-4810 DVD Displays " PLEASE WAIT"
to open the tray during "please wait", remove casing then loosen front panel (clips either side and underneath). Power up to get "please wait", then press small microswitch in bottom right corner of the DVD player unit. Have you tried resetting the unit (turning on and holding the power button for at least 5-10 seconds)? Have you tried unplugging the unit for a longer period of time (24 hours)? get your firmware upgrade through here(sorry its in german, you might be able to get an english of it through the LG site) - http://www.lgupdate.de.ms/ two cd's- bootloader.iso , update.iso Good luck
May 16, 2006 | LG DR-4810 DVD Recorder
LG RH177 DVD Recorder/HDD Recorder Logo
622 people viewed this question
