I cannot get rid of the error message telling me there is a paper jam, front and rear. There is absolutely no paper caught in the front or rear of this machine. I have checked with a flashlight at least ten times. This printer is three months old and is currently unusable.
SOURCE: paper jam message
Richie, I ve had the same message and was wondering why: You have to open the printer.You will find rest of paper near the left side gear wheels(where powercord is pluged in) which cant be seen from outside. Another point is that the encoder strip (foil paralell to printhead belt) might be out of position. The jammed paper hamight had pushed the encoder out of position. the encoder strip has to be fixed upon the printhead.
SOURCE: I cannot get the BACK COVER OPEN message to GO
There is a little cover there that has a sensor flag on it. It is most likely in a jammed position. If you are able to carefully take the cover out, you can bend it slightly, readjust the sensor flag, and reinstall it.
Thanks
SOURCE: Paper jam rear, open back cover. Paper jam has
Hi Good day!!! Turn off your brother and check the back cover be sure to close it. after that turn back on your brother.
Thanks for using FixYa
Don't forget to vote thanks
