My camera is quite new, only a couple of months old and I have been downloading photos onto my computer. But,for the last couple of days, I have found that my computer is not 'recognising' the connection. Nor can I recharge the camera. Might there be something wrong with the USB connector making connection with the camera?
To make it possible, to point out where the problem is, you could try some rings.
Try to charge the camera with an external power supply. If you have it, the F-2AC from Olympus.
If that also does not charge, you could try to replace the USB cable.
But if the camera starts charging, you have to look for the USB connector in the computer. Be aware, in some computers the power, delivered from a USB connector, should be capable of giving 5 volt and 500 mA. Sometimes internally the computer is not correct wired, and won't give the 5 volt at all. Special when you hav build the computer yourself, you can check inside the computer. BUT ONLY when is sure the camera can charge via an external USB charger.
Then you could check if nothing is wrong in the camera. All contacts, on battery and in the camera, should be clean and shiny. You could clean contacts with a dry cloth. Never use sharp tools.
Also check the USB connector on the camera, if no debris is in the connector, or no contact is bent or has corrosion on it.
Success
Testimonial: "very good information but it is definately a problem with the USB connector on the camera. If a contact is bent or has corrosion, what do I do?"
SOURCE: No usb port found
I also have a problem tranferring from my Olympus digital camera. I hope some one will be able to help. I am working on Windows XP SP1. When I first tried to transfer pictures from my Olympus when the computer was new,the pictures transferred through the USB port with no problem. I then added a printer to the USB port and worked fine. I added a Zip drive to the other USB Port and that also worked fine. When I went to transfer pictures again, I had to disconnect the Zip drive from the usb port and connect the camera to the port. It would not work. I checked device manager and it did not list the camera in that port but the Zip drive,even though I had disconnected the device. I restarted the computer with the camera connected to the USB port and still it did not work. Device Manager still listed the Zip drive in that USB Port. The transfer worked fine before I used the USB ports. It seems that it always recognizes the Zip Drive and not the camera. The Camera and drivers are listed in device manager but not in the USB Port. Anyone,please help.
SOURCE: Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
SOURCE: Vista not recognising Olympus camera on USB connection
I just spoke to Olympus Tech Support.
You have to download Olympus Master 2. (Their program is no longer called Camedia Master.)
http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp
At their main site, search for olympus master 2.
SOURCE: Fuji Finepix Z won't load photos onto my computer
check the memory disc it might be full in which case it is best to save the pics onto your computer and then wipe the disc for room to take more pics.
SOURCE: olympus stylus 790 sw:windows vista does not recognise the devise?
there is none, olympus shld bl00dy fix the problem
