Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How to format
My pendrive was in problem, i cant format my u3sandisk pendrive.
  • 13 more comments
  • ciyt Nov 07, 2007
    My Sandisk Micro cruzer 2.0 could not be detected. the light turns and gows off right a way. Tried to position it with no lick. help.
  • Anonymous Nov 18, 2007
    it won't work
  • Anonymous Nov 25, 2007
    i am unable to write/delete anything from my sandisk cruzer pen drive
  • sahil garg Dec 07, 2007
    i have techcom pendrive. I am unable to format it. when autoplay starts the pen drive then window asks to format it. When i checked the properties of the drive then it shows no capacity. Plz suggest me the solution for this problem
  • vijeesh Jan 06, 2008
    i have transcend 1GB pendrive i'm unable to format it even it not shows reformat in properties ... also it get detected but says insert drive H:
  • Anonymous Feb 22, 2008
    I have problems with my USB. please help!
    Here are the problems i am dealing with:
    1. when i'm trying to delete files on my USB, a dialog box appears saying "There is no disk in the drive. Please insert a disk into drive \Device\Harddisk3\DR11.".
    2. when i am transferring files from PC to USB, the dialog bx says "Cannot create or replace [file name]: The device is not ready".
    3. when i'm trying to format the USB, a dialog box appears again saying that "Windows was unable to complete the format." then the windows explorer will switch to control panel.
    4. sometimes, when i am plugging in the USB, the window if the drive is opening like a pop-up, and it won't stop LIKE CRAZY until i eject it.
    i tried to download OnBelay but it has a licensure key and i couldn't access it, also tried to format it in disk management but it says "The format did not complete successfully." in a dialog box.
    i also tried to visit the site of the manufacturer of my USB, but it has not any guides for these kind of problem.(cd-r king is the manufacturer)
    if you have any ideas dealing with these problems, please let me know.
    email me at u_munjal@yahoo.co.in
    thanks in advance.
  • mugil Mar 04, 2008
    There is no disk in the drive. Please insert a disk drive \Device\Harddisk1\DR5.
  • Anonymous Mar 20, 2008
    i can not download my mp3
  • Lordships May 09, 2008
    I am having the same problem, i have some addition information that may be helpfull though. My flash drive quit working after i accidently wiped the MBR on it during my windows admin class. So the data is still there but there is no MBR and i get the same error.
    I relized i originaly posted this in the solutions section, Whoops.
  • Anonymous Jun 05, 2008
    it is showing that the drive can't format.
  • Anonymous Jun 15, 2008
    my sandisk 1g shut down i cant open
  • gopi440 Jul 03, 2008
    i brought a pen drive and when i put to my system and want to open it.a message came to format first.when i tried to format it says windows was unable to format how to get solved this problem
  • Anonymous Aug 12, 2008
    when i click on format, it shows the error ' windows was unable to complete the format'
  • Anonymous Aug 25, 2008
    how to format problem
  • p3168 Mar 18, 2009
    lost all programing
    Brigadier General:
  • 5,158 Answers
Just run the u3 remover... if you want to remove the u3 program and format the entire usb drive...
it can be found here
http://www.mydigitallife.info/2006/09/11/disable-remove-and-uninstall-u3-launchpad/
Robert
Posted on Sep 06, 2008
Posted on May 09, 2008
  • 1 more comment
    I've got a solution!! Or so it worked for me. When trying to reformat a USB drive. If you get "Windows couldnot complete the format" or whatever the error was. Right click on "My Computer" click on manage. Click disk management. Finaly right click on your flash drive and click "New partition" Follow the wizard. FYI this is kind of a half-@## workaround. let me know if you run into problems. :) have a nice day.
  • Lordships May 12, 2008
    Yes i Know its your pendrive. Im refering to my USB sandisk flash drive. They both plug into USB ports do they not. Try my solution i think it may work.
    FYI Pendrive/USB Flash Drive/ Jump Drive/ Removable USB drive. Are all the same thing.
1.run...cmd
2.Format F:/fs:Fat32 [ F should be change to flash drive name]
3.enter ....wait the results
Click Ads in my web for thank me at www.review1.net
Posted on Mar 23, 2008
I have a sandisk pendrive 4 GB. The problem is "windows is unable to format the drive"
Posted on Jun 04, 2011
>Comment by Lordships, posted on May 09, 2008 >I've got a solution! Or so it worked for me. When trying to >reformat a USB drive. If you get "Windows couldnot complete >the format" or whatever the error was. Right click on "My >Computer" click on manage. Click disk management. Finaly >right click on your flash drive and click "New partition" Follow >the wizard. FYI this is kind of a half-@## workaround. let me >know if you run into problems. :) have a nice day.
This one worked for me perfectly after having the "Windows could not complete the format" error. Note, I ejected the "cdrom" that U3 was mounting before hand by going to right-click on my computer, click on manage, click on storage, then removable storage, then media. The cdrom will be alongside the U3 Sandisk Cruzer Micro USB, and it will be owned by Sandisk as well. Right-click on the cd-rom, then click "eject". Then, follow the comment above by Lordships for reformatting instructions.
Posted on Jun 17, 2008
No itz not working thr is no reformate option
Posted on Jan 30, 2008
How to format SanDisk 2GB Cruzer Micro USB Flash Drive...
Posted on Jan 27, 2008
  • 31 Answers
You can remove the autoplay virus by cleaning the registry contents.
Posted on Dec 13, 2007
  • 27 Answers
Go to my computer right click on the usb device and go to propetries and then if you see reformat then click on it
Posted on Dec 03, 2007
I want 2 run exfat pendrive in windows xp
First, your Windows XP must be either SP2 or SP3, and then you must add a patch to it. http://support.microsoft.com/kb/955704/en-us that is KB955794 for the patch
Jun 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My mosearbaer pen drive cant be formatted and we also cant delete any files in the pendrive???
virus in your pendrive.
so format your pendrive dos command
start than run than type cmd than enter
ok and command type is
format (your pendrive colon) enter
i sure your pendrive format.
Feb 26, 2010 | Electronics - Others
My pendrive is write protected how to format it ,it says that the disk is write protected and i can read the content in it but cant delete the contents what should i do to remove the problem
my pendrive is write protected how to format it ,it says that the disk is write protected and i can read the content in it but cant delete the contents what should i do to remove the problem--ATUL
Nov 07, 2009 | Macally iBall Trackball
I can't format my pen drive.
Click > Start > RUN > type "CMD" Then
Type "CHKDSK" and type o your Pendrive and "/F". Ex. chkdsk Q: /F > Enter
Ok, You see many msg error. OK!
Now, you remove your pendrive and plug again.
Try to format.
It works well.
Thank You
Aug 06, 2009 | Transcend (589307) Media
Write protected
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
May 23, 2009 | iLO (2 GB) MP3 Player
I cant format my transcend usb 2gb it says write protected
Hi
The pendrive seems faulty or corrupt but there might be a possibility that you recover functionality. I think you might be using XP or VISTA. Whichever the OS use another computer with A DIFFERENT OS (so if its XP go to Vista or vice versa) and FORMAT it. You should be able to get your pendrive working again. If not it is tough luck time!
Cheers
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cant able to format my pendrive .. the right protected or use another disk
CHECK THE BACKSIDE OF UR PENDRIVE CHECK THAT IT IS NOT LOCKED THERE!!!IF IT IS UNLOCK AND TRY TO FORMAT!!
HOPE THIS WORKS FOR U!!
Jan 29, 2008 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
5,229 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
