I understand the diagram with the +12v and the gnd wires, but does the third wire only work with other Kenwood products? It appears to be a "sense" wire or similar that feels the presence of a powered-up source unit (cd-player, etc.) what would I send on this wire to use the eq in a different situation? (or is it superfluous)
The third wire is commonly called a "remote" wire and is used to turn on other devices, such as an amp, connected to the audio system. When the equalizer is off, there's no signal on the wire. When the equalizer is on, a low current 12V signal is on the wire, signalling the remote device to turn-on.
Hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenwood KGC-4042A 5-Band Car
I am building an exerciser for a brake control module. I need the schematic for the Delpi ABS module...
(More)
I am building an exerciser for a brake control module. I need the schematic for the Delpi ABS module for a 2002 Corvette
I have a eq 6500 pioneer but nothave the the power supply conector, only can see the pines in the...
(More)
I have a eq 6500 pioneer but nothave the the power supply conector, only can see the pines in the componet. apreciate any help thanks you .
tengo un equalizador sentrek saq-2009 , y no tengo el esquema de conexion , como puedo conectarlo ,...
(More)
tengo un equalizador sentrek saq-2009 , y no tengo el esquema de conexion , como puedo conectarlo , alguien sabe? gracias
Hello, I have a kenwood KGC-7043 EQ. I bought it off of e-bay and it is an older model (1995). It...
(More)
Hello, I have a kenwood KGC-7043 EQ. I bought it off of e-bay and it is an older model (1995). It came with a wire harness that does not match the original. It plugs in but all the wires are different colors. How can I identify which is which? thank you, Glen p.s please note the model is kgc-7043
