I have moved my canon c2020 from one office to another. Both offices have different modems. How do I connect to a new modem?
First decide whether your going to use the LAN hard wired or wi_fi wireless. Then locate the ip-adress of the new network the name of the domain. or ssid of the new modem or net work example:att who ever is in charge of the adminstration rights to the new network. plug the machine into the router if its dhcp the router will take from there. on the machine go into additional functions<network settings<ip address. with the ip address of the new network you will clear the old and replace the new,example192.168.1.1. if you have a smart phone it will help you find these necessary numbers to plug in. or go to browser and type in http://192.168.1.254 this will get you to the router or modem. it will display a data page with a lot of numbers. you will need its password and its on the modem/router back or bottom. then look for devices on the network you should see the machine look at the ip the router/modem gave it. write it down match the machine with same number and hit print 192.168.1.254 will let you send test page. or call a IT man.
