Question about HP DeskJet F380 All-In-One Printer
Printing the same picture all the time?whats wrong
I try to print an invitation but the previous picture that i printed was the one that kept printing several times. how do i print a different image?
  • HP Master
  • 1,113 Answers
Go to priner and faxs in control panel double click "hpdeskjet" driver icon, window should open with pending jobs, you can delete them before they get to printer, if jobs are at printer then power off and on of printer will clear its memory of jobs requested
maybe too one of your pictures is bigger than the paper so your printer is trying to finish very big job. either way powering off printer and deleteing jobs in driver then power on printer will enable next job to be sent
Posted on Oct 29, 2007
SOURCE:
I've been using OKIDATE MICROLINE 320 PRINTER at work. I was printing something and I realized that I was printing the wrong page so to stop printing, I simply turned off the power and waited....
You would have to cancel the current print job from your computer for it to stop. Assuming you have access to a computer that is connected to that printer, you will have to find that printer by going to Control Panel > Printers and Faxes > Oki ML 320 then right click, select "See What's Printing" and cancel Current print job (I am also assuming you are using windows). I really hope this helps, if not add a comment clarifying your question, thanks.
May 23, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
My Kodak ESP3250 printer won't print invitations. It just keeps spitting out the invitation and telling me I have the wrong size paper.
This is common with these printers. When you go to print and the kodak dialog print box comes up you need to change the paper size manually for the printer. The printer does not always take the correct paper size from the program you are printing in if it is a custom document.
another word of advice. USE THE TEST SHEET FIRST. This printer does nto correctly print invitations you need to offset the items about 1 inch to the right or so. Test before you print the real things.
Jun 13, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Three weeks ago, I purchased a Black (No.4) and a Colour (No.5) Valuepack Cartridges for my Lexmark X2690 All-In-One printer from Refresh Cartridges/UK. After installing both cartridges, I printed a Test...
ok what should do is when you finish printing one page wait for some few mins before printing another page ok. that could help or unistall and reinstall your printer again and apply this method i just showed you. thanks
Jul 02, 2009 | Lexmark X2690 All-In-One InkJet Printer
Printer says to re-insert paper face down.
You must have the default printer settings changed to "double-sided" printingor "print on Both sides".
Check in your printer properties: 'Right click' the printer icon. Select "properties", "Printing preferences", "finishing", un-check "print on both sides" (these options vary slightly by printer model, so just check around on the different buttons).
That's my best guess. :)
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
The date doesn't appear on photo when printed.
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Feb 07, 2009 | Olympus FE-250 Digital Camera
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Sep 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Having problems printing photos from photo gallery.Printer prints pictures from previous attemts and not the one required.I have uninstalled thed programme but disconnected the printer first.Was this wrong...
Open the photo from photo gallery, doubleclicking orn it or selecting it with one click. Ensure in last case it is marked in blue. It should print the right photo in this way.
Apr 10, 2008 | Office Equipment & Supplies
Print Size
you have to choose the paper type in the printer driver option wheather envelope or A4 paper see the preview before printing
Mar 22, 2008 | HP Deskjet 3915 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
57 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
