Question about Hitachi 42HDT52 42 in. Plasma HDTV
Green colour flashes
We have suddenly started getting bright green flashes of colour when any dark colour appears on the screen. Has anyone else had this? We have tried to reduce the colour but this does not help at all.
    Problem Solver:
  • 5 Answers
I have a42hds52a and someone threw something at the screen and broke it. so I am looking for someone who is willing to get rid of thier tvgreen colour flashes - 1.gif or looking to buy one for parts.
call Richard At916-308-9272
raystockett@inbox.com
Posted on Jan 26, 2008
Flashing colours on screen
You have the review feature active and the flashing colors are most likely showing you the highlights and shadows that are too bright or too dark for a good photo. Look for the features in the menu to turn them off or try a factory default reset from the camera menu.
Oct 19, 2014 | Kodak EasyShare V1003 Digital Camera
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
Sony Vaio colours on screen inverted and dark. I
if you are using the computer then you have to change the vga cable
Aug 02, 2013 | Sony VAIO Computers & Internet
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
The green fades in and out
Its most likely caused by a bad solder joint on the Green CRT dive board which is located on the bootom of the green CRT ( Center CRT) which you can accesss by removing the front speaker panel then the small access pane behind the speaker panel. If the solder appears good the green CRT itself is most likely defective.
Nov 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Picture is green and fuzzy in shaded areas
I have only see this issue caused by either a defective main bd. or a defective A/V bd. I am sorry but both would require a new bd and no simple repair exists.
Jun 18, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Try # 2... Green Fog
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Feb 26, 2007 | Toshiba 32HFX71 32" TV
Hitachi 42HDT52 42 in. Plasma HDTV Logo
159 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
