Computer problem Sir, i have a problem. Every time i disable local area connection it shows the following error message. It is not possible to disable the connection at this time.This connection may be using one or more protocols that do not support plag-&-play,or it may have been initiated by another user or the system account. How can i resolve it ?
Find and change mrxdnp.sys file to mrxdnp.old problem sorted
Posted on May 21, 2010
    Novelist:
    Scholar:
  • 167 Answers
You should make sure that you have administrative previlges to do this.
Some programs may have prevented the network service from being disabled.
This can also be caused by a virus too. So you also install and run a full system scan. Don't rely on a single antivirus. try different one if one doesn't solve the problem.
Some worms prevent the networked systems to be controlled by users of the administrative groups.
also remember that most of today's networks are equipped and monitored with network monotoring ultilities. some of these also acts as firewalls too. This may prevent you from disabling the local area connection.
If nothing works at all, just pull the network plug (RJ45). will disable the network connection. this way the appliaction that is using the connection is likely to display some error message. if this is a freindly application change the configuration settings of this application so that you could control the lan connections.
Posted on Oct 29, 2007
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
I can't apply my welcome screen..every time i click it..a prompt shows that clients services for net ware are disabled the welcome screen and fast user switching.To restore these features, you must...
Follow the following steps to uninstall client services:
  • Click to Start button.
  • Click on run.
  • Type control.This will open 'control panel'.
  • Click at my network connections.
  • Right click to Local Area Connections and select 'Properties'.
  • `Highlight local area connection for netware by clicking it once.
  • Click on the uninstall in the same dialogue window.Follow the instructions.
  • After uninstall action is completed then click ok in the same dialogue box.
If you have further query then tell me one more time. Thenks for using FixYa.
Aug 24, 2011 | Microsoft Windows XP Professional
Error 321
You get this error when you try to install the router using the CD.
This error shows that your computer is not connected to the router or the connection between the router and the computer is not working. When you run the CD , it will ask you to connect the computer and the modem to the router with the cable. You will see all the lights lit up on the router according to the instructions but still you will get error 321.
In this case you will need to check the firewall settings of the computer. If there is any firewall installed on the computer, then turn it OFF. Make sure that the Local area connection on the computer is not Disabled. The local area connection should not have any static IP address assigned. If there is any then set the IP address to automatic.
Try to run the CD again and see if that works. If that doesn't work then try to setup your router without the CD. You can setup your router manually.
from http://fixhomenetwork.com/blog/error-321-router-setup/
For help in setting up router without the cd go to:
http://fixhomenetwork.com/router-set-up.php
May 18, 2011 | Linksys WRT120N Router
Local area connection is disabled
Hi, open your Computer and follow the Instruction-
For XP
  • Open Control Panel and select Network Connection
  • Open Network connection
  • Right Click on Local Area Connection, show as Two Pc and select Enable/Disable
For Vista
  • Click on Start
  • Then Control Panel
  • Then Network and Sharing Center
  • Manage Network Connections. Right click on the Icon and select Enable.
  • Most HP
May 17, 2011 | Computers & Internet
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
When I start up laptp show the
hi,
-there is a possibility that the computer is searching for a bootable device; disable the drive A in the system setup
-if you are using Windows Vista you may press F8 while the computer is starting up and select disable error messages on start-up.
cheers!
Oct 19, 2009 | Dell Inspiron 8600 Notebook
Network Connections missing icon. Plus others problems.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
Jul 31, 2009 | Computers & Internet
No internet connection,
hi
if you have already configure your router and it was working following thing could have happen
1) you have lost connection to internet ...go to your router setup page under status make sure you have connection
2) once you have your router connected re-boot your laptop or pc or renew your wirless connection
good luck
Jun 12, 2009 | Linksys WRT54G2 Wireless Router
Error message 388
Hi! Error 388 means the local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames.
If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Use the link below-
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153695&prodTypeId=18972&prodSeriesId=1153695&objectID=buu02549
Jan 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
