Question about Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung 216BW I have a 216BW that has a damaged LCD screen due to impact. I am interested in replacing the LCD with one from a used monitor. I'd like to buy a monitor that has bad power supply but a good TFT LCD. What are the typical symptoms of a bad power supply? Maybe flickering? Won't power on? Powers on briefly but shuts down? Thanks for the assistance.
  • 11,361 Answers
All of your mention symptom. see example of bad caps: http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
Posted on Dec 22, 2009
Syncmaster 216bw monitor..stuck in power saver mode..power light blinking
Did you try this monitor with another PC yet? VGA cable connectors are properly seated?
This model (same chassis as the 223w) is known for haing bad caps in the power supply/inverter board as shown here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20223bw/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | Samsung SyncMaster 216BW Monitor
No power in my samsung 216bw monitor
Look for bad caps, it uses the same board as 223ww as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Oct 20, 2010 | Samsung SyncMaster 216BW Monitor
Lcd monitor flickers
Check the pc resolution first then your video cards and try new vga cables. If nothing happen the monitors has internal problem may be the mosfet IC of inverter area is shorted. The solution is replace IP board.
Sep 19, 2010 | Samsung SyncMaster 216BW Monitor
When I press the power button on my Samsung Syncmaster 216BW it goes to source test but does not turn off the monitor
That is main board problem may be the EEPROM is defective could cause of cannot save or store current settings. You need to replace your main board to fix this problem.
Sep 09, 2010 | Samsung SyncMaster 216BW Monitor
Need Synmaster 216bw driver
Here is the driver download from SAMSUNG website
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=216BW&prd_ia_sub_class_cd=P
Just click on the driver, it is the same one as you listed '20070515103345609_SM223BW'
No need to uninstall the old driver, all the driver doese si to allow you to set the resolution that is not listed in the microsoft video resolution lists.
Jun 29, 2010 | Samsung SyncMaster 216BW Monitor
I have 3 samsung monitors and all of them went black within weeks of each other and they are only 2 years old, whats wrong
That is about right time for the monitors to fail, look for bad caps in the power supply first and report back so we can guide you further, see example of failed SAMSUNG monitors due to badc caps: http://s807.photobucket.com/home/budm/allalbums
They are made to fail, even MAC uses cheaply made parts.
Feb 04, 2010 | Samsung SyncMaster 216BW Monitor
Samsung 216bw Stuck in standby mode
hi try putting near rad or uses and hair dryier, i hope thie work
chers
Dec 09, 2008 | Samsung SyncMaster 216BW Monitor
Where I can get part for 216bw Samsung
thanks but The monitor was checked, the technician told me that he tryed to get the video card of the monitor Samsung 216 BW but they don't know were buy a part like this to replace it the broken.
If you can please, let me know where I can buy parts of Samsung monitor 216 BW.
Thanks.
Sep 25, 2008 | Samsung SyncMaster 216BW Monitor
Lcd hd tv conected to my pc do not work
Try going through the settings in properties on your computer
Aug 04, 2008 | Samsung SyncMaster 216BW Monitor
Broken LCD
To me it looks terrible and have no idea to repair it. I don't think you can fix it. How did get the screen broken? I used to repair a monitor from Dell. The CCFL lamps inside are broken. My screen is still OK. I would suggest that a new screen is a better choice for you if you have enough budget.
Thank you
Mar 26, 2008 | Samsung SyncMaster 216BW Monitor
Samsung SyncMaster 214T 21.3" LCD Monitor Logo
191 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
