I have a 2 speed pool pump. The breaker kept tripping so I tried to troubleshoot the problem. I am an electrician by trade but unfortunately have never had or dealt with pools. I took the pump into a pool...
Coming into the back of the motor...
4 wires? Right?
Red, Black, White, and Green
A 2 speed will be 4 wires - additional Red wire
A 1 speed will 3 wires - no Red
The black and red wires are your speed wires,
they will go on to your 'line' connections...labeled on the motor next to the spade connection as 'H' and 'L'
the white wire is your common or neutral wire,
it will go on the space connection with a 'C' next to it.
and the green wire naturally is ground. Normally attached directly to the base of the motor.
I cannot tell you specifically which wire is low-speed or which wire is high-speed. Because different spa control manufacturer's alternate or vary the use of colors for low/high speed. Unfortunately it is not standard. But if I was to venture a guess, the majority of these control manufacturers, use red wire for low speed.
I have also seen at times, that the label is Misprinted. Where the common and low-speed are switched?
in my experience, and I have wired and many, many motors. Both two speed and single speed motors.
The common is almost always either at the top of the spade connections, or the middle spade connection, I have never seen in my recent experience, where the common connection is at the bottom.
This in common problem, may or may not be the case for you.
to your question specifically:...
Both speed wires are not on the same relay, are they? Or is it a contractor?
(normally two different relays on the circuit board for the different speeds of the pump)
Unless there is a normally closed and a normally open spade connection?
is this a mechanical spa control system, or is it a digital electronic, with a circuitboard, spa control system?
