Question about Microsoft Windows XP Professional for PC
Step by step for system recovary on xp pro
Need step by step instructions
  • 167 Answers
Re: step by step for system recovary on xp pro
First find the windows product key, and write it down. the firts thing you should do is to enter the BIOS setup. When you switch on your system you may be asked to press a certian key. for e.g. "Press DEL to enter setup". press the relevant key. Change the boot sequence to set the CD ROM first.
then you put your windows CD in  the drive and reboot the system.
When it displays "press any key to boot from CD." press any key.
After a while, the system displays options for Installation. Press Enter key.
Then folow the instaruction on screen.
When it displays a message like this...
"C:\windows xp professional"
Press enter and then just follow the onscreen instructions like a normal installation. This way you would be able to recover your windows XP system and bootloader if damged.
Do not select the option to format, partition or delete your Documents and settings. this may damage your system and personal files.
Posted on Oct 29, 2007
0 characters
3 Points
I have an AMD Athlon 64 x2 D/C 5200+...i ma running XP PRO ver 2002 sp pk 2......when I donload sp 3 after reboot i get a blue screen with a whole of code on it and nothing else
Just do a system restore to the last restore point right before you did your update to sp3.
You can get step by step instructions with pictures on how to do it here:
Jun 04, 2012 | Microsoft Windows XP Professional for PC
I need to download installation instructions
Find the installation instruction for Windows XP,
May 30, 2011 | Operating Systems
How do I upgrade my windows 7 to XP or atleast 2000? Pls help
you mean how do you downgrade your windows 7 to xp, you will need a copy of xp and boot from the cd and follow the instructions to install XP
Mar 28, 2011 | Microsoft Operating Systems
I mistakenly install windows xp pro over my current operating system which is also windows xp now i want to uninstall the newly install operating system to go back my previous operating system. I had tried...
What you can do is to bring the computer back to time before installing XP Pro.
Go into Start - All Programs - Acessories - system Tools - system recovery and here choose according to the calender a piont/date before installing XP PRO.
The computer will be brought back timewise to a point/date of your choise.
Feb 26, 2011 | Microsoft Windows XP Professional With...
How to insnatal the windows xp
This website provides excellent step-by-step instructions for installing Windows XP Pro:
Dec 23, 2010 | Microsoft Windows XP Professional
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
Steps to format desktop,and make it work faster,few maintainability steps.
Please if you do have a bootable windows xp pro cd or dvd, that will do, just put the cd into the dvd Rom and reboot the system, and follow the instruction as they come
Apr 29, 2010 | Microsoft Windows XP Professional for PC
Recovary of product key for my seriyal no
product key for the windows xp is :
try this , or else you can get this from the
Mar 29, 2009 | Microsoft Windows XP Professional With...
Itunes for windows xp won't install on my windows xp pro pc.
Be sure you go the version for windows , not mac. also make sure you did not get the 64 bit windows verison. its easy to get the wrong one.
Good Luck
Jan 07, 2009 | Microsoft Windows XP Professional for PC
Problem w/ WIN2000 Pro & XP Pro
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional for PC Logo
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
