Question about Stanton STR8-30 Turntable
Turntable won't spin - Stanton STR8-30 Turntable
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
Aiwa lx-110 turntable won't spin
chances are that is the drive belt for the platter, check you local radio shack, they used to carry or be able to order those kinds of things
Mar 09, 2013 | Audio Players & Recorders
Turntable won't spin, even after switch the tonearm right
Hi, most likely the belt has come off or is stretched. Cheers John. Styluscity
Nov 22, 2012 | Crosley 0187SST Turntable
I have a supersonic dvd player and it won't spin at all.Model no sc-178 dvd
sorry to say but most likely case is bad motor or turntable issue of some type. unless expensive unit cheaper to buy a new player.
Nov 03, 2012 | Televison & Video
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
My turntable won't spin - the spindle is fine and it makes half hearted efforts to move but will only **** a few times and then stop.
The self-lubricating bushing in the turn-table is dried out. This is a difficult problem to solve and best left to an expert. Don't expect great results.
Sep 06, 2011 | Stanton ST-150 Turntable
Stanton STR8-30 Turntable Logo
42 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Anthony
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
