Question about Canon NP 7130 Black and White Copier
Error "E0" on a Canon NP 7130
I get error "E0" as soon as I turned unit on then it shutts off after about two seconds. I have some service documentation and it says error E000 (I'm assuming it's the same as E0) is something to do with the Fixing Heater circuit. I measured with an ohmeter the Fixing heater (disconnected from the Composite Power Supply board) plug and I get around 14 ohms. So at least it looks like the heater and the thermal fuse are okay.
I guess it could be Thermistor TH1. But how do I check it?
Any suggestions and recommendations would be much appreciated.
  • 1 more comment
  • schooltech Jan 16, 2008
    e0 and then off , I tried replacing the fuser assy but same code is ther a reset process? or any other sugestions
  • sorlen Jul 12, 2008
    When i press the green button, EO and 30 are flashing simultaneously. I turn it off then try to start again, its still like that.
  • fendonde Feb 15, 2009
    Yes I have same problem mine flashes E0 then 03 then swithes off what Can i do which part is infected
    Festo Ndonde
    Problem Solver:
  • 5 Answers
E000 on a 7130 is a lockout error it needs to be reset. you need to remove the control panel remove the 2 screws that attach it to the body on the left and right sides open the **** shell and pull toward you. Flip up on the top of the unit with the circuit board facing you look for two metal jumpers labeled jp103 and jp104 short across the 2 with a small screw driver to enter service mode( can be verified by an "F" in the display) power down the copier reinstall the control panel and reboot. If the fixing assembly is good the error will be cleared
Posted on Jun 07, 2008
What's the solution to E0 problem for NP 6512 copier?
Posted on Dec 10, 2008
Ok eu reset o 103 104 and its ok
its work
tanks
Posted on Mar 21, 2011
  • Canon Master
  • 1,113 Answers
Thermister should be neither short or open, it should change resistence reletive to temp of unit,
Check Heater lamp and thermal fuse independantly
Becarefull when playing in HV areas.
Posted on Oct 29, 2007
SOURCE:
Error E0
Canon Copier np7130F Error E0. Please give sugation above this problem solutions.
Oct 26, 2010 | Canon NP 7130 Black and White Copier
Received an E2 error then it says 10??
• The lens unit does not turn on or off the lens home position sensor (PS2) within a specific period of time when the lens unit is being moved. 71cc10b.jpg
Oct 15, 2010 | Canon NP 7130 Black and White Copier
I have an E0 code
Check the main thermistor,the thermal switch,the heater lamp.This components it is in open circuit.Reset the error code in service mode.
Sep 27, 2009 | Canon NP 6551 Black and White Copier
Flashing error code e000 then goes off
Error code E000 error in the fixing unit...thermofuse is broken or thermostart is out...to know this you must know how to open the fixing unit...and check the thermofuse and the thermostart with multitester...or see if the heater lamp is turn on...
Jun 10, 2009 | Canon NP 7130 Black and White Copier
Canon NP 1215s photocopier error code E0
did you check thermistor, I think that you have a problem with thermistor, not only thermoswitch! what about black copy - did you check is expo lamp (under the original glass) is lighting or not, if not - it's normal to have a black copy!
Success!
Jan 03, 2009 | Canon NP 6551 Black and White Copier
CANON NP 6012 ERROR CODE
Most likely it is the fuser unit.
as soon as you turn on it does not rotate it gives you an error and turns off.
take out the fuser (where it gets hot at the exit) and check hte lamp (probably burnt out)
or the fuse
Oct 16, 2008 | Office Equipment & Supplies
Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Sep 16, 2008 | Canon Office Equipment & Supplies
Error Light
This is the add toner light. Replace the tube of toner and will be well.
Dec 28, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
1,738 people viewed this question
Clive
Clive
old marine
old marine
