Canon ip1880 alignment problem
All vertical line i print out become zigzag
i have done the print head alignment many times
i even change a new cartridge
the problem only occur on COLOR cartridge, black is OK
plz help
SOURCE: print head alignment failed
Head Align Failed
Posted on Apr 17, 2008
SOURCE: Printer won't print color only black and white
Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
Posted on May 24, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
SOURCE: magenta won't print have done deep
It sounds like your print head my be blocked. On some printers they come with the cartridge, my canon has separate print head that can be replaced.
Posted on Jan 24, 2009
  • 49 Answers
SOURCE: I keep getting this message
The print head is the carriage that holds the ink cartridges and has tiny nozzles on the bottom that spray the ink on your paper. The nozzles have to be aimed (aligned) either automatically, or in WinXP with the following manual process:
1 Left click on the start button
2 Open "Printers and faxes" on the Start menu.
3 Find your printer on the printer list and right click on it once.
4 Select "Properties" from the pop-up menu.
5 Click on the "Maintenance" tab at the top of the new window.
A selection page for all sorts of upkeep items is then shown. Manual alignment of the print head is one of the choices.
Posted on Feb 24, 2009
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Vertical lines when printing. Have genuine Epson cartridges installed and most are brand new. Have done a print head alignment and cleaned the nozzles.
You have a clogged print head. If repeated running of the head cleaning routine does not work, you can take a Q-tip and dip it in warm or hot water and gently rub it across the print head. You should see ink on the Q-tip. Do this a couple times until it appears that more ink is flowing then try the head cleaning routine again. This is a common problem when inkjets sit unused for awhile.
Mar 10, 2011 | Epson R1900 Printer
Printing a table the vertical lines shift left/right about the width of the line as the head moves back & forth. This only occurs with the black cartridge in use, not the color cartridge. The black...
sounds like you replaced the black cartridge, do you run the "align print head" on the printer. Sounds like the black is not aligned to the printer input.
Jan 10, 2018 | Hummingbird CannonLink Ink Feed System
My epson stylus photo printer is printing a black vertical line in all my prints. I have done the head cleaning and print head alignment several times. Is there anything else I can do?
black vertical lines on the printout comes due to some reasons.
1) if the black cartridge is near to its end it will give black lines instead of proper printing.
the cartridges gets over many times due to head cleaning and deep 3-4 cleanings cartridge gets one cleaning 4 ml of ink gets puled out of cartridge.the whole quantity of cartridge is near to 25 ml.
but if the cartridge is full then the problem is of cartridge head .the head is the part in which you insert the cartridges if the head is got blocked internally to its holes from where ink comes out.then there are two methods to clean the head one is head cleaning which you did.the other is removing the head by disassembling the printer and then cleaning the head manually with isoprophyll liquid.but its a time consuming and tough job.a local printer repair center will be advisable,
and in some cases it has seen that cartridge gets air pressure problem inside and due to that it leaks inside the printer so replacing that cartridge solves the problem.also many times the cartridge gets leaked and that leaked ink gets collected and stuck up on the roller of the printer from where paper passes so the strips of ink gets printed on the this case no head cleaning but cleaning the internal roller of the printer with tissue paper helps.the procedure is called servicing.that can also be done at local printer repair center.or you can do it manually by using tissue paper.but to service whole printer it needs to be disassemble.
check out his option.thanks.
Nov 20, 2009 | Epson Stylus Photo 1290 InkJet Printer
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Prints vertical lines crooked
You should be able to go into the print driver settings and do a print head alignment.
That should cure the problem.
Jan 15, 2018 | HP PSC 500 All-In-One Printer
I have a X7170 it has recently began printing with vertical blank areas on the printed copy. In other words up and down on the page there missing copy. I have changed ink cartridges and this does not help....
Uneven vertical lines can be adjusted by
performing the printhead alignment adjustments.
The user is directed through the Lexmark Solution
Center to perform the printhead alignment
adjustments when replacing a printhead cartridge.
The alignment can also be performed from the
control panel by selecting the Maintenance Option,
then Align Cartridges.
Feb 01, 2009 | Lexmark X7170 All-In-One InkJet Printer
MP780 vertical lines on photos
Hi. the problem is the print head, maybe is clogged or damage, try this remove the cartridges , and the print head and submerge the print head in hot water for 3 minutes, dry the print head and reinstall it, if problem persist replace the print head.
TCT How to remove and clean Canon Printhead
May 02, 2017 | Canon PIXMA MP780 All-In-One InkJet...
932 people viewed this question
