Question about Accton CheetaHub Power 3016P (EH3016P) Networking Hub
Accton CheetaHub Power 3016P not working
Power is not comming in Hub. We check power point and power cable, which is ok.
Kindly advise on e-mail id zdmwadmin@adityabirla.com or zdmwadmin@hindalco.adityabirl.com
Regards,
Replace with the same one...
Posted on Feb 25, 2008
    Problem Solver:
  • 10 Answers
The built in power supply of the switch will be defective. Please contact any good TV technician since it is a SMPS power supply. The repair procedure is same since TV has a SMPS power supply.
Posted on Oct 29, 2007
Driver for win 7 pc
You dont need any driver for your device.
Jan 22, 2014 | Accton CheetaHub Power 3016P (EH3016P)...
Our local LAN is connected for 6 windows 7 computers using an Accton CheetaHub 2040. LAN speed is 10Mbps. We get a lot of lost connections to our local server. How can we increase from 10Mbps to 100Mbps?
100Mbps in not the solution, because the computer NICs are not being utilizing nearly to 10Mbs. You may have a 10/100 or even 1000 (1GB) Network Interface Card, but you will never get those speeds. Not on a desktop anyway.
Example: COX offers Internet Professional a max of 15Mbps download, and 3Mbps upload for $200 a month w/3yr plan. You would need 4 such connection totaling $800 dollars a month to reach 10Mbs, and this is one the cheapest plans out there. I'm don't know your service plan, but I assume the budget is a great concern.
T1 = 1.54Mps
http://www.t1shopper.com/
Enough rambling, let's talk solutions. Get another hub to test out. Like a Netgear or Linksys. Get new cat 5 cables.
Then the server needs to inspected to see if the failure is there. Check the event viewer for warnings and errors. These can be very technical though. Is there high CPU usage? What about the NIC setting? These actually matter.
Finally what about the DATA provider and their equipment. Have them test out since they are the first point of entry.
GL
Oct 26, 2012 | Accton CheetaHub Classic 2040 Networking...
Im looking for an upgraded version of Accton WN4201B 802.11g Wireless PCI Card
One of the newest drivers is http://tim.id.au/static/WN4201B.zip
If that is not new enough, there is a newer one in a damaged install package. I can point you to it if this driver is not new enough.
Aug 27, 2010 | Accton WN4201B 802.11g Wireless PCI Card
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
Need user manual or installation manual for Accton EtherHub - 8e
Please send an E-mail to support@accton.com.tw should you have any technical support issues or login your personalized username and password to our AccOEM system.
Dec 20, 2009 | Computers & Internet
Where is the on/off switch? It is plugged in but no power
I believe, through searching, that this is an Accton.com.tw (accton.com) product. Having trouble find this model, is it old?
Probably doesn't have a power switch. I found a manual for 3016A:
http://mars.accton.com.tw/ww/accton_manuals.nsf/0/a216d6504b9202f7482566d5003337ef/$FILE/eh3008a_16a.pdf
And it just says plug the power cord in.
* Anyway why would you need a power switch for a switch-hub? Once it gets plugged in it pretty much stays on all of the time.
Of course you have no power. You're unit is probably dead for some reason or the other. Maybe you could open it and look for a fuse or other power supply problem? Assuming you have no warranty on it. If you do have warranty then you should pursue the warranty path for help with it. They seem to have USA support information.
Internet: support@accton.com.tw
USA Headquarters
P.O. Box 51420
Irvine, CA 92619-1420
Phone Numbers -
Sales: 949-707-4800 or 888-398-2101
Support: 949-707-4847 or 888-398-4101
RMA: 949-707-4828 or 888-398-3101
FAX: 949-707-2460
"Why couldn't you just find a nice Japanese Girl like all of the other white guys here?" --- Quote from the movie Fast and Furious: Tokyo Drift.
Nov 22, 2009 | Accton CheetaHub Power 3016P (EH3016P)...
What is the ip address to accton chtah hub router
It will be 192.168.2.1 ... or you can try default IP for other routers ... 192.168.1.1 / 192.168.0.1.
Regards,
Shrey
Oct 08, 2009 | Accton CheetaHub Classic 2040 Networking...
No have Drivers Accton CheetHub Classic 2040 Win XP
If this is a hub no driver is required, connect your CAT5 cable to it and the other end to your Network interface card and it is done.
Visit http://www.accton.com/ for more informtion.
Jul 03, 2009 | Accton CheetaHub Classic 2040 Networking...
Got an accton eh 2024 etherhub and wanna network 2 computers
Forget Windows XP networking wizard.Go to control panel>network connections>right-click on LAN connection>properties>select TCP/IP>click properties IP: 192.168.1.100Subnet: 255.255.255.0make the other PC's IP: 192.168.1.101To allow file sharing go to Control Panel>windows firewall>check file and printer sharing and click ok
Mar 27, 2009 | Accton EtherHub 24S (EH2024) Networking...
Not making a connection to broadband router
Hi, If I understand you right, you installed a hub after your router, all your PCS are connected to the hub and it is working. Then you should not be concerned, first, you did right, second, as long as it works and isn't slow or disconnecting then no issues. A few buts: 1. If your router has 4 ports, then you don't need the CP3008a and 2. why only "2 lights on cp3008a" if you have 2 PCS + the router, you should have 3 lights; At the end of the day,if it works and you have no complain, let it be. Kind regards.
Aug 24, 2007 | Accton Refurbished CHEETAHHUB POWER-3008A...
Accton CheetaHub Power 3016P (EH3016P) Networking Hub Logo
246 people viewed this question
Top Accton Computers & Internet Experts
David Payne
David Payne
Are you an Accton Computer and Internet Expert? Answer questions, earn points and help others
