Question about Home Satellite Radios
No display when turned my dreambox dm500-s
I just flashed my dreambox dm500-s with flashwizard using lan connection. when reset and turned on no display on tv.
0 characters
1 Points
How to set up dreambox dm800 satellite receiver
The easiest way to start may be to find an image (firmware) backup and flash that to your box. Many have posted backups of their image that are set up and ready for use. Be sure to find the correct image for your box model.
If you want to set every thing up yourself from scratch, there are many things to explain. Better if you try first and then ask the specific questions about the problems.
Most things you set up from the menu, like Audio/Video settings, network, language, satellite dish setup etc. And some other things you might need some other tools and knowledge to do, like ftp and telnet.
For reading your smartcard for watching encryted channels you might need to download a softcam. On some firmwares this is easy enaugh from the menu, on others this is not so easy accessable.
Please just try, and then ask. Be sure to tell the exact problem and what image you are using.
One good source for images and more information is
Oct 19, 2013 | Home Satellite Radios
How to Watch Digital TV use Dreambox satellite receiver?
Most video streams are digital, so just by watching tv from any sattelite does mean you are wathing digital tv.
But I suspect that your question is related to IPTV, which are digital tv streams from the internet. There are IPTV plugins available for the dreambox, and even some youtube tutorials for how to set them up. Do a google search with keywords iptv dreambox to find out more
Apr 20, 2013 | Delphi Roady XT XM Radio Receiver
I need a users manual for a Jensen Sirius VR187 satellite radio. Where can I get one?
This site will let you download the owners manual for your radio.
Dec 05, 2012 | Home Satellite Radios
I had the same problem. This procedure from the "Technical Questions" section of worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Reactivated Sirius Radio today. Display shows P1, p2.p3, etc with flashing channel 184. Unit will not work. Tried soft reset with Sirius, still no luck. Sirius said to go to the dealer and have them do a...
Disconnect negative wire from vehicle battery; wait minimum of 1-hour, then reconnect.
Turn on satellite radio, call Sirius tech support to have them resend activation signal. Stay on line with them since it may take them 2 - 3 tries.
Aug 27, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Home Satellite Radios
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Home Satellite Radios Logo
326 people viewed this question
Top Home Satellite Radios Experts
Brian Sullivan
Brian Sullivan
Jose Cada
Jose Cada
Are you a Home Satellite Radio Expert? Answer questions, earn points and help others
