Question about Compaq Presario 700 470024-192 Notebook
Cnt see anything
My laptop is not working i m charging but nothing appears
    Problem Solver:
  • 8 Answers
Hi
replace your power adapter and try it in normal mode if warkingthen replace your battery if not warking try to power on with another battery same model if then also not warking go to nearer service vender or service center.
by by.
Posted on Nov 19, 2007
VGP-PRS20 port replicator stopped working
I haven't use replicators much but the one on My dell is still working.
I will suggest to remove the laptop(you probably did already) and then insert a USB and see if Windows says anything about it, do the same with the other components. If nothing works then I think the unit is bad or the connector on the back of the laptop is bad.
Of course if you had a similar replicator you can test your laptop and see if its port is bad.
Jun 07, 2014 | Sony VAIO Notebook
My toshiba satellite L25-S1194 wont turn on. no lights, nothing. how could i fix this?
Try taking the battery out, plug the computer in, and see if it turns on. Press the "Power" button for at least 20 seconds (and press hard). If that doesn't work, put the battery back in, and do the same thing. I assume no lights appear like its charging (as you said). If this is the case, then you might have a dead charger (wire broke inside, power surge broke the adapter, etc). You may want to try a different charger of the same model (either from your local Best Buy or from a friend). If it does look like its charging, then your laptop's power supply has died (or the motherboard has died). This is a much bigger hardware problem and should be under warranty (or time to buy a new laptop). All data should be recoverable, however.
Jun 19, 2013 | Toshiba Satellite Computers & Internet
Hi my sony vaio vgn cs36gj is frozen and making wierd noises from the fan it frozen on the desktop with the start menu up the desktop has also gone a bit pale also cnt do anything on it it wouldnt even...
possibly yes. this sounds like its overheating and locking up. need to know what operating system you are running and whether you hear the fan running or not
Jan 28, 2011 | Sony VAIO Notebook
How do i reset the counter for a Lexmark e260d after replacing the photoconductor kit?
After replacing all the items in the photoconductor kit, reset the maintenance counter: 1 Press and hold the Select and Return buttons while you turn the printer on. 2 Release the buttons when Performing Self Test appears on the display. The printer performs its power-on sequence, and then Config Menu appears on the first line of the display. 3 Press Menu until you see Reset Maint Cnt and then press Select. Reset appears on the second line of the display. 4 Press Select. Resetting Maint Cnt Value appears briefly on the display, and then is replaced by Config Menu on the top line and Reset Maint Cnt on the second line. 5 Press Menu until you see Exit Config Menu, and then press Select. Activating Menu Changes appears briefly, followed by Performing Self Test. The printer returns to the Ready state.
Dec 02, 2009 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Nokia 6233 hangs after switching it on.
you should reflash your phone.
try to download nokia firmware on www(dot)blue-nokia(dot)com
and to flash your phone with usb
you need to download BB5 reaper software
or you can use J.A.F emulator (c r a c k of J.A.F)
first you need to download the software of JAF, Instal it, and run the emulator
the program opened.chose BB5 tab and tick the USB connection.
before you flash your phone, instal your phone firmware ( don't downgrade version ).
insert the MCU PPM and CNT on each tab.
MCU is the micro controler
PPM is the data contain the language (choose the PPM code that contain your language)
CNT is content data (choose the CNT code same with the ppm)
or you can select the correct product code, it will automaticly set the MCU PPM and CNT
Sep 23, 2009 | Nokia 6233 Cellular Phone
Toshiba Satellite P200 RT2 won't startup but is holding a charge just fine. Power light, charge indicator, battery indicator appear normal, just nothing on the screen. Please help.
Hook up an external monitor and see if windows loads up, if so it might be a backlight or inverter. if you dont see anything then it might be a hardware failure
Mar 20, 2009 | Toshiba Satellite A135-S2276 Notebook
Failure to work
Hello Ruxi,
The problem could be viral in nature.
Are you running an Anti Virus application, and if so are it's virus definitions up to date?
Do you hear any sounds (through your speakers, or the hard drive spinning) when you re boot the computer? And what do you mean by "it just broke down"?
Have you tried to enter your BIOS or boot to "Safe Mode" on boot or do you not even see anything on the screen at all ever now?
You can try the above if you haven't already, and let us know what you find.
We'll be checking on this, and Good luck.
Mar 18, 2008 | Acer Aspire 5100 Notebook
Acer aspire 1705 smi charger problem
The power supply is detecting a fault. You are probably correct thinking it has the wrong pinout.
Before you pull it apart, consider returning it to the seller if it was sold with incorrect information.
If you disassemble anything, your refund/replacement and warrantee will be voided.
Nov 08, 2007 | Acer Aspire 1705SMi Notebook
Compaq Presario 700 470024-192 Notebook Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
