Question about Lexmark X3350 All-In-One InkJet Printer
Printer cartridge My colored cartridge keeps on saying that it is empty but I have a cartridge in there!  What do I do?????
  • 38 Answers
Thats lexmark inkjet printers, reinstall it with  the computer on and tell it its a used cartridge
Posted on Oct 29, 2007
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Keeps on saying cannot detect ink
if your Brother's printer is anything like mine, it won't print in any color (or black/white) if any one ink cartridge is empty. I just put any color cartridge I had in the empty slot to force it to print black and white.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Brother MFC 6490CW InkJet Printer
The printer keeps doing the alignment and saying that there is a problem. My color ink cartridge is low but I would still like to print with black ink. I don't know if the color cartridge being low affects...
Replace your color cartridge and power printer on. The color cartridge is probably empty (even though there might be a little ink left in it). Many inkjet printers require the color cartridge for composite black even if you are not printing in color.
Jun 16, 2010 | Dell 926 All-In-One InkJet Printer
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
I have replaced all the ink cartridges and my printer says "no cartridge, open scanner cover"
It is probably best to replace cartridges individually as necessary. Let me explain. The printer display will tell you when a cartridge is "xx near empty" and when "xx empty" (where xx is the cartridge color).
1) Near Empty - you can continue to print. This message is to remind you to get a new "xx" cartridge and have it on hand.
Replacing the cartridge when "Near empty" will cause the machine to report "xx Empty" when it is not. It will not register that you have replaced it at "Near empty." Wait to replace the cartridge when you get the "xx empty" message.
2) XX Empty - you may not be able to continue printing. Replace cartridge "xx" now per your manual.
If you have replaced or reseated more than one cartridge, and you get the "no cartridge" error, you need to find out which one the machine "thinks" is problematic:
1) With the scanner cover open and locked in the "Up" position, the message may change to "Change cartridge, install xx" (xx refers to the color )
2) After changing the suspected cartridge and closing the scanner cover, be sure to notice the display. It will say, "Changed XX? 1. Yes 2. No" Press 1.
If all this explanation does not work, keep it in mind for next time. Brother says to unplug the machine for at least 10 seconds, then plug it in again. If the display shows the date and time, problem solved. If not, you may need to contact brother support.
Jan 22, 2010 | Brother MFC 420CN All-In-One InkJet...
Trying to reload color cartridge.
Many brand name printer cartridges have a code that tells the printer they are a new cartridge. Once the cartridge is empty it will never again tell the printer that is it new.
You can refill the cartridge but it will continue to tell the printer that it is empty.
You say you "had my ... cartridges refilled today" so I suggest you go back to the folks who refilled them and ask them for suggestions.
Otherwise, purchase off-brand cartridges that won't tell the printer they're empty and keep refilling them as needed.
Another approach: purchase a new printer that won't give you this problem. I refill my Lexmark cartridges without any problems.
Dec 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Printer won't process new catridges. These cartridges have been refilled.
Did you install the original cartridge? if you have the old empty cartridge, try to install it and check the error is empty cartridge..if so the problem is the newly installed cartridge. try to buy the new original one.
Dec 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark X3350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
