Question about Husqvarna Garden
Stihl fs110r wont idle, wont get on step.new coil, new carb., adj
Changed carb., changed coil, and adjusted valves
  • 1,041 Answers
You might want to check the fuel lines for crack/breaks.
(TIP: If the carburetor is a used one, you probably ought to clean the small portals in the carb. with a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152). They work great for this job!
Jim
Posted on Jun 12, 2009
  • Jim Parker
    Jim Parker Jun 15, 2009
    Did this solve the problem?
    Jim
SOURCE:
MY Stihl BR-550 Has a rebuilt Carb, Clean spark arrestor, New spark plug, fresh 50:1, valve adjustment, filter, new pull cord assembly. The issue...it binds then smooth when pulling, cant get any rpms
Suggest you try:
1) Flywheel key could be sheared. It is located under the starter drive cup/armature coil magnets just beneath the recoil assembly.
2) starter drive cup rubbing on ignition coil
3) ignition coil failed due to rubbing causing heat failure
4) valve adjustment .002" clearance
5) valve lifter cam worn or brokent
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jan 12, 2017 | Stihl Garden
Stihl FS110R trimmer I can't keep it idling
increase the idle speed via the tuning screws on the carb
Apr 15, 2013 | Stihl Garden
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
Wont idle
Make sure your spark plug is not fouled and the gap is correct, also air filter is properly cleaned. If it still wont idle, locate the idle adjustment on the carb. There are 2 screw type adjustments there, one is the idle/air screw and the other is idle adjustment which is the one you want. Start the bike and warm.it up, slowly turn the idle adj. Inward like tightening a bolt, periodically give the engine a slight rev and let it idle.down. Do this until you reach the desired rpm you want to idle at and your finished
Mar 24, 2012 | 2002 Yamaha TT-R 125
My 83 GL1100 goldwing will not idle i have good firing at all cylinders but sitting on the bike the 2 left side exhaust pipes have good heat out exhaust while the 2 right are just warm,are there adjustment...
first try cleaning the carbs, new spark plugs and adjust valve clearances, new oil and clean air filter, before any screw adjustments, which will need some vacumn gauges attached to set the carb sync
Mar 25, 2011 | 1983 Honda GL 1100 Innerstate Gold Wing
Need to adjust my honda shadow 500 vt carburator's fuel/air mixture
start by synchronizing your throttle plates. Honda calls the next step the "idle drop procedure". u need to know if you have fuel adj. screws or air adj. screws. fuel screws will be on engine side of carb slide, air screws will be on airbox side of carb slide. start leaning out mixture, (turn in fuel screw, turn out air screw. idle will increase so keep adjusting idle back to spec.after each turn if needed. Adjust about 1/4 to 1/2 turn at a time on each carb until there is no change in idle, then richen up mixture by one half turn. If u sync throttle plates first then follow this procedure, there should be no hesitation when you "blip" the throttle, and after revving it should return to idle smooth,
Apr 08, 2010 | 1986 Honda VT 500 C Shadow
STIHL FS110R weedeater won't start, does not hit at all. Cleaned plug, spark arrester and air filter, what's up? Like new!
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Mar 11, 2009 | Garden
Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Jan 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
368 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
