Question about Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
Dell 924 Printer.
I have a Dell Printer#924 and the paper feed is not working
  • 2 more comments
  • Anonymous Nov 04, 2007
    paper is not feeding properly, only one side is grabbing
  • Anonymous Dec 06, 2007
    yes, my 924 also will not print because the paper feed function is not working. I've tried all I can think of to clean the apparati that might pull the paper....but nothing.
  • Anonymous Mar 19, 2014
    At the print command, the printer cant seem to grasp the paper to feed it through.
  • Anonymous Mar 30, 2014
    printer doesn't works
I also am having the same problem whereby the paper feeds into the printer crooked. Only one side of the paper is being grabbed. I tried the microfiber towel to no avail. I believe that the spring on the level bar is worn or needs tightening BUT I can get in to the printer. Any ideas on how to open the back of the printer up so I can get at the level bar spring?
Posted on Feb 03, 2008
    Genius:
  • 1,003 Answers
You need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Posted on Jan 07, 2008
2 Suggested Answers
amarie99
  • 7 Answers
SOURCE: My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Posted on Jun 24, 2012
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
My Dell 924 CLAIMS it has a paper Jam and does NOT.... it will not clear this out and I can't print anything! Help!
check the feed rollers for a dirt build up , they can be cleaned with a damp cloth, the probable cause is slipping feed, the printer expects paper and none is fed due to the slipping of the rollers.
look where the front edge of the paper sits, there are rollers there that bring the paper into the printer, clean them.
Jan 11, 2011 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
Paper keeps misfeeding in Dell AIO 924
I first wonder if you have children. if so, then open the lid and/ or look in the paper feed area for plastic tools, band aids, etc. (worked in tech support and once had a gerbil stuck in a printer by it's tail! OUCH!)
if you can't see anything, then take a letter sized piece of poster board and try to run it through, that should clear any foreign debris (such as paper clips or pieces of post-it notes that you may not be able to see) good luck!
Feb 10, 2009 | Dell 924 All-in-One InkJet Printer
Paper does not feed
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Feb 08, 2009 | Dell 924 All-in-One InkJet Printer
Paper doesn't feed right.
Normal 0 Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Dell 924 All-in-One InkJet Printer
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Dell --924 copier
clean feed in roller with rubbing alcohol on a micrfiber cloth if there is white reside on rollers you just have a traction problem
also make sure no torn paper is in the paper feed area
Dec 19, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
438 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
