Question about LG DLG5988 Gas Dryer
Dryer damaging clothes
DRYER BRAND GE....problem is clothes lways get caught at the edge of the drum causing the clothe burn,holes , and makes an dark color brown oval shape stain on the there an easy fix on this or i  need to call an repairman?
    Problem Solver:
  • 19 Answers
Call repairman if you are not mechanically inclined it will be worth the money spent.
Posted on Nov 09, 2007
Making thumping noise and burning clothes
You list no brand or model so an answer must be somewhat vague. A loose drum causes the noise described while it also allows air to leak from outside the normal air flow path causing erratic high/low temperatures contributing to burning. Sometimes clothes can also get caught in the gaps caused by the tub moving excessively which causes tears, pinches and rips in clothing. Most dryers will have rollers and/or glides to carry the weight at the front of the drum. Check to determine if these are worn, loose or broken. A few models carry all the weight at the rear of the drum (Frigidaire and some GE) so check the rear bearing for excess wear and replace as needed. It's always a good idea to also clean debris and lint from inside the cabinet while the dryer is disassembled for repairs.
Aug 25, 2014 | Dryers
Ge dryer makes holes in clothes
That is worn glides and bearing like in this video I made:
Oct 11, 2012 | GE Dryers
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Brown streaks left on clothes
Not having seen this before, but my best guess would be that the piece of clothes is caught in one position and rubbing on the gasket material around the rear of the drum. Is the mark permanent?
Apr 16, 2009 | Whirlpool ET8CHEXSQ Dryer
GE DSXH436V1WW heavy duty large cloths get caught
This dryer doesn't have rollers at the front of the drum, it uses a felt rub strip between the drum and the front cover. You'll need to replace the rub strip. It's easy to do but you'll need to get the special high-temp adhesive.
Feb 24, 2009 | Dryers
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
LG DLG5988 Gas Dryer Logo
267 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
