Kenmore 23.1 cu. ft. Side-By-Side Refrigerator w/Acceler-Ice & SpaceSaver Ice System
Problem for Kenmore 23.1 cu. ft. Side-By-Side Refrigerator...
Kenmore gsi-23 refrigerator not getting cold
By bigduane28 on Jun 12, 2009
kenmore gsi-23 refrigerator not getting cold enough and freezer is not defrosting
Solution #1
posted on Jun 12, 2009
Somewhat Helpful)
Greg20
Rank: Guru
Rating: 91%, 82 votes
without a continuity tester this is nearly impossible but the components are defrost control/defrost heater/ defrost thermostat. with freezer frozen unplug and disconnect defrost t-stat attached to evaperator coil on top corner(looks like short stack of nickels with 2 wires) check for continuity..in ice should be closed. also look for top to be pushed up crooked if misshapen replace. next check heater for cont. be sure to disconnect first. if both of these are good.."continuity" then it must be the defrost control.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
TheMobilian
Rank: Guru  Kenmore Expert
Rating: 89%, 707 votes
You need to take a look at your defrost configuration. The first thing to do is check the heater. Then check the terminator and then check out the defrost timing device. (read more)
Was this helpful?
Yes
No
Popular Solutions for Kenmore 23.1 cu. ft.
Questions and Unsolved Problems for Kenmore 23.1 cu. ft.
Do you recommend Kenmore 23.1 cu. ft. Side-By-Side Refrigerator w/Acceler-Ice & SpaceSaver Ice System?
Answer
Answer
viking range oven door repair
Answer
kenmore acceler-ice doesn't work, red light flashes when door open
Answer
The ice machine makes ice fine. It's the electron button. When crushed ice is pressed, it works... (More)
Answer
Kenmore side by side model: 51232105, purchased Mar 02. Makes buzzing noise about every 3 to 4... (More)
Answer
water is not getting into ice maker. How do you get water into tubing?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 23.1 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
