Question about Insignia IS-LCDTV32 32 in. Television
Please help I have IS-LCDTV32 in. I can't turn tv on. Where is power board located and how big is it?
Http://www.fixya.com/support/t123763-tv_hard_time_turning
check out this posting on fix ya, i just fixed my tv this morning.
Posted on Nov 03, 2007
Open the back of tv the power supply is right there . there are 3 caps on the top left change those and it will work fine
Have to hold power button down to get insignia 32" to turn on. Now it won't turn on at all. Before it would turn on easier if I tilted it on its back. No capacitors inside look to be damaged or bulging...
I had similar problem with a 42" Soniq plasma TV.
The fault was the start up / power up circuit board at a cost of $180 Australian including labour.
Alternatively:
The serviceman told me that it's not uncommon for him to see On/Off switches on plasma or Lcd TV's that have jammed up inside the TV even though the switch / button still appears to be working normal outside of the TV.
Feb 18, 2010 | Insignia IS-LCDTV32 32 in. Television
My zenith big screen tv won't come on model pvr5263dt
Hi
Thanks for using FixYa. This might have happened due to over-voltage. Please check the power supply unit for swollen capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. This issue might have occurred due to blown pico fuses located on the D-Board or due to blown fuse on the power supply board.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 22, 2009 | Televison & Video
Sorry to say but I believe you have what the rest of us have had happen to our TV's. There are three capacitors on your TV's power board that have gone bad. It is an easy fix and I only paid $5.16 for the capacitors required for the fix, but if you don't have the desire to do it yourself the power board is available on bestbuy.com for about $100. You can replace it easily enough with a philips screwdriver.
Make sure you un plug it first.
This seems to be pretty common with alot of LCD TV's from what I've seen here recently.
Good luck with it,
John
Apr 12, 2009 | Insignia IS-LCDTV32 32 in. Television
Tv off light only comes on.....
replace the power supply.There are two possible power boards used in this model. Order according to the number on the original.
Advent 667-L32K5X-20W SEE NOTES BOARD, POWER (IF THE BOARD HAS 782-L32U25-200B) Advent 667-L32K5-20C SEE NOTES BOARD, POWER (IF THE BOARD
Jan 21, 2009 | Insignia IS-LCDTV32 32 in. Television
I have a 32" Insignia TV (IS-LCDTV32. In normal operation, when TV is off, the LED on the front is solid red. In normal operation when I turn teh TV on, the LED turns blue and the TV turns on. In the...
If your LCD is less then a year old, I would suggest to contact the manufacturers to have it fix under warranty.
The failure on your LCD could be a defective back light inverter or a power supply not providing enough power to the back light inverter board.
Let me know if you require further assistance.
Oct 14, 2008 | Televison & Video
Parts for Insignia IS-LCDTV32
Click here to find the power supply for your TV. Keep in mind that these power supplies boards are pulls from used LCDs.
Good Luck.
Aug 22, 2008 | Insignia IS-LCDTV32 32 in. Television
IS-LCDTV32 32 will not stay powered on
Went dead? no power light? if you had no lights at all its probably the power supply, if you had a red light then I would go with the main board. Disconnect the lcd panel from the main pcb and inverter and see if your blue light stays on. If so you have a bad panel.
Aug 21, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Feb 02, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
55 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
