If it is brand new, it is likely "pilot error" as setting these up if you are unfamiliar with mixers can be frustrating.
There are several things that must be done to have a working system. Correct speaker cables are one and the setting of all the knobs are important...
DO NOT REPLACE FUSE. If any LED's are on, fuse is OK. If fuse blows, service the unit before replacing fuse to avoid further internal damage.
Make sure speaker cables are good.
Set the level control for the channel you are testing up AND you may need to press the "PAD" button to change the input gain. Turn up the master gain.
Depending on the source you are using, line or mic you may need to change the PAD button.
NOTE: This mixer does NOT have Phantom power and cannot be used with CONDENSER microphones requiring phantom power. You will get no audio from a condenser mic without phantom power. You must use dynamic mics with this mixer.
