Hi, i have a washing machine whirlpool AWO 12763, in running program it get water and after few minutes i received this message "Alarm sense water tap closed, open the valve and press "" to continue". If i press the restart key the machine take the program again from the start.
SOURCE: Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
SOURCE: I have several problems with
Hi.
F-22 is door lock error. The door lock was already defective and now has failed completely. You need to replace the door lock.
Here the error explained in detail:
F22
DOOR LOCK ERROR
Theme Door Lock message is prompted when the door cannot be locked. The CCU (central control unit) will try to lock the door six times before displaying the F 22 error code.
Possible Causes:
The door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
Repair Procedure:
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock, and the central control unit.
Regards.
Ginko
