2002 Ford F150 Regular Cab Logo
Angelia Turner Posted on Mar 03, 2014
Jerking in my f150 stx 2006 - 2002 Ford F150 Regular Cab
B-Dubb
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 31, 2014
B-Dubb
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
373
Points
I'd suggest the cheapest fixes first. I had the same issue and it turned out to be the coil pack. Cost-$20 Time- 10 minutes.
Did this after changing the fuel filter and plugs and wires three times. Its definitely worth your time to try the coil pack first. Oh, also make sure none of your spark plug boots or wires are grounding on the egine. That will give you the exact same symptoms. Hope this helps!
3 Related Answers
Anonymous
  • 31 Answers
  • Posted on Apr 14, 2009
SOURCE: P0302 Cylinder 2 Misfire Detected in 2006 f150 STX
Looking at the Engine on a ford is different from a gm. The correct cylinder numbers are 1234 from front to back on the passenger side and 5678 front to back on the driver's side
fordexpert
  • 5692 Answers
  • Posted on Jul 13, 2010
SOURCE: 2006 f150 jerks when going 500 55mp took her in
Check your in Service date and see if you may be under Warranty. If not, if you changed your plug there was a individual coil on top. That should be changed too.
Also remember to clear the codes by taking off a battery cable for 10 minutes. Autozone and Oreillys will scan for free.
clifford224
Clifford Beard
  • 1975 Answers
  • Posted on Feb 20, 2011
SOURCE: where is the fuse panel
I'll do my best to explain where it is but I wish I had a picture for you. I hope you understand. This is from the owners manual. The fuse panel is located under the right-hand side of the instrument panel. remove the trim panel and the fuse box cover to access the fuses. I hope this helps and good luck.
2006 ford f150 Stx 4wd,is there 2 plugs on here
Sometimes the drain plug can only be accessed after the skid plate is removed. There is one there somewhere. Also be advised, a lot these newer transfer cases can require Mercon V ATF, not 90W gear lube. Make sure you re-install the correct fluid!
Minimum front rotor thickness 2006 f150 stx 2wd
1.12 inches
have at least 1.14 inches for machining if you have less than 1.14 inches left machine shop will not do it, just go get a new one
I have an 2006 f150 5.4 liter..when I take off the truck sometimes jerks, and when I go to accellerate to pass, it seems to drag and the emission light comes on. What could this be?
maybe low fuel pressure or a vacume leak i had a 04 f150 4.6 i had a vacume leak on the back side of the motor it would surge at idle and was slugish but it was a bad leak
Where is the fuse panel for 2006 F150 STX ?
2005 F150 STX
There is Sometimes an Option in the Owners Manual to Stop this. Most of the Time though you cannot as it is a Safety Option.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
