Question about Nokia N70 Cellular Phone
Nokia n70 not recognizing sim card
I have bought a nokia n70 open line while I was on vacation in the Phils. it is an open line. It worked fine with my tmobile sim card, then suddenly it began asking to reinsert my sim card. I tried trying other sim cards from other providers, same problem, I tried my old sim on another phone, no problem there. I've tried to hard reset it, same thing, even put everything back to its factory settings, same thing. would appreciate any kind of suggestions. thanks. i've tried to google it, and the only thing it suggested was resetting my phone, or update it.
  • 425 Answers
Re: nokia n70 not recognizing sim card
Are you a pinoy???
anyway, probably the sim loss its contact to its sim terminal... try inserting together to your sim a folded paper same size of your sim( just to compress your sim to its rterminals)... be sure not to cover the sim terminals...
Posted on Oct 29, 2007
0 characters
3 Points
Sim card busy;
nokia asha 305 plzzzzz format code give me
Nov 01, 2013 | Nokia 101 Dual Sim Flashlight Music Mobile...
Open line sim
To openline your Nokia N70 from network lock use unlock code.Visit the site get unlock code for low cost and unlock easily using the unlocking instructions in the site.Check whether unlocking service is available your network and country your Nokia N70 locked now..If it is available get it and unlock easily.Then use any other GSM network sim card in it.
Jul 15, 2013 | Nokia N70 Cellular Phone
Nokia 6670 is not supporting AIRTEL SIM. It is saying " insert SIM" every time I insert AIRTEL SIM. Mobile working fine with other SIMs.
Sir / Madam, please check your cell phone if open line so it can be able to recognized the sim card if it is open line try to remove the sim card and scratch it with pencil eraser
Jun 19, 2011 | Nokia 6670 Cellular Phone
Every time i insert my sim card into my phone and switch it on it tells me to insert a sim card and the phone stays in offline mode and cannot be put back into general or silent(n70)
remove the sim, battery, and memory card then clean your sim with eraser then try it on. if problem continues try a new sim and if not work again no other solution but to consult a technician.
Mar 28, 2011 | Nokia N70 Cellular Phone
Saying no sim card inserted in my nokia 6111, but my sim card works in other fones
hi im josh in cebu phils. may i help you? As a mobile phone techinician, Friend i will say that the problem centers on your phone and not on the sim card.
You phone is locked to the network of that SIM or commonly mentioned "not open line" thats why the software or the phone doesn't recognizes the SIM you are using because it is locked. To solve this problem you may go to your network provider and ask for assistance of opening the line of your phone so that you can use any sim cards you wanted. and your phone will now be unlock or "openline".Thats all friend hope i helped you good luck
Mar 10, 2009 | Nokia 6111 Cellular Phone
Sim ic
hi im josh in cebu is very simple friend if your phone doesnt recognize the sim. clean your sim card reader with a brush slowly friend. then be sure the connections to the sim firmly contact because lost contact may gve such problem. good luck. hope i helped me so that i wl know if i helped you so.thnks.
Feb 23, 2009 | Nokia 1600 Cellular Phone
URGENT!!!! Unlock cell
u cant unlock ur fon by urself..coz it uses some software to unlock go to the nearest cellfone technician and just tell them to unlock that and they will just know what to do with that.. :D
Aug 25, 2008 | Nokia N70 Cellular Phone
Nokia N70
Go to Setting-Network-Operator Selection. Keep it Automatic
Go to Setting-Call-Send my caller ID. Keep it Set by network
& check your line in use. Keep it in Line 1
Jul 06, 2008 | Nokia N70 Cellular Phone
Nokia N70 insert sim card problem
u have to connect ur mobile with ur computer and make it flash set Sim Lock Intialise.
Jun 10, 2008 | Nokia N70 Cellular Phone
Nokia offline
where did you bought your phone? if you bought it from a telecom's promo it means that your phone is locked to a single network provided only. you can ask a technician to have your phone OPENLINE for you to be able to use any kinds of sims.
if it's not the case, check the slot for sim and make sure that the sim is properly placed. restart it without the sim and then restart again but now with the sim.
Sep 23, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
134 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
