Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Leave it plugged in for about 10 minutes. The battery just needs to charge a little more. Then you can come out of sleep mode.
If it is locked in sleep mode. Just hold the power button down to shut off the computer. Let it charge, you can now reboot, and keep charging after about ten minutes.
make clear you have conected every cord onto its original position. be sure that cooling system works. some computers get stuck when they get too warm too quick.
To remove the sleep mode: right click the desktop and select Personalize, Click screen saver, at the bottom of that window you'll see "Change Power Settings" Click on that. Next to the left side of the window click on "Change when the computer goes to sleep and change the setting to "Never".. As far as why its doing it is unclear without hands on work, but you should have warranty for it. Tell them to fix it or try a differ brand of PC.
If you unplug the unit for an hour or overnight, it should go out of sleep mode. If this dosent work then its not in sleep mode and the set has a problem in the power supply or the sweep circuit. Sorry you should seek a pro to assist you in this repair. Good Luck
