Question about IBM eserver xSeries 200 8479
Setup of a 200 8479 60x Server that has been Erased
Wher can I find a copy of the serverguide for this system 847960X ? It is in the doc, "BRDID228 Chapter 4. Using the ServerGuide CDs" But I can not find A Serverguid that supports this system
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    What OS are you running??
    Arcadian
    Problem Solver:
  • 17 Answers
Www.ibm.com usually has these
Posted on Aug 19, 2008
I am setting up a Xseries 345 server using ServerGuide 7.14 everything runs fine untill it start to copy files it than gives me a blank screen and nothing happens after that
This is probably a Server Guide issue. You may check with one step lower verion and one step higher version of server guide. It may solve issue.
If that doesn't work, you may have to manually install OS without server guide. You can use a either use a floppy drive or pen drive to load controller driver. Once installed, rest of the drivers can be downloaded from IBM site or install from server guide cd
Thanks
Dec 07, 2012 | IBM xSeries 345 Server
Can not install 2003 server in ibm x 236 as it is showing no drives are present
hi,
You should download the IBM ServerGuide software in order to install win 2003 on 236 server.
You can download it from the below link. It's a image file , so after download burn it into cd and boot server from cd and follow the instructions .
http://www-947.ibm.com/support/entry/portal/docdisplay?brand=5000008&lndocid=MIGR-57504
That's all
Thanks
Dec 13, 2010 | IBM x3400 Server
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
How do i get a IBM Xseries server to recognize a serverraid card
IBM Serverguide will most likely get you going again. Go this link:
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008. You can download the ISO image for the version of Serverguide that will let you configure your system. If you have a Xseries 360 version 7.2.03 should work.
I hope this helps. Good luck!
-jodair
Apr 03, 2009 | IBM eserver xSeries 360 8686
Erase data from IBM x serie 306 Model: 8836-2MX
I'm assuming that you have SCSI drives in there. IBM has a built-in utility to manage these drives. Just watch the boot messages and it will tell you what key to press to bring it up.
Even better would be to go to the IBM site and download the image for the IBM Serverguide. I think you're looking for version 7.4. Check this link: http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008.
-jodair
Apr 02, 2009 | IBM eserver xSeries 200 8479
Ghost array0 over to newly setup array1 problems
I should assume the CD drive is SCSI? What sequence is it set to come up in? Set it at 2 if possible. Have you checked, or better yet replaced the CD drive? Will it boot with ANYTHING else?
That Hiren's CD is not uuummm, kosher? People having problems booting with it and all, plus the utilities may not have full function anyway. No matter what, you will need to f/disk the destination drive. You will still need the CD drive to install the program too.
Backup software will still make an exact copy of your drive also. You might want to consider a little better product, especially concerning disaster recovery. not to get off topic but, a quote from J. Bolton on backup & recovery
"What will you do if a user overwrites a 1000page doc with a blank file with the same name? What will you do if one of multiple server apps goes bonkers? If the mainboard dies how will imaging get your system back? Do you stock a spare board so the image restore will work on the exact same hardware? After a system crash, Acronis True Image Enterprise Server allows you to perform a full system restore, a bare-metal restore or just a restore of individual files and folders.
Complete system restoration can be performed to an existing system, to a new system with different hardware or to a virtual machine. You could setup a whole new system and dump the image on that.
Dec 04, 2007 | Dell PowerEdge 2600 Server
Server guide for the 3500m20
Have you tried http://www-304.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008?
It may have what you're looking for.
Nov 20, 2007 | IBM Netfinity 3500 M20 8657 Server
IBM Netfinity 5600 8664 81Y Server
The disk that comes with the machine is called the NOS in the manual. It is also known as ServerGuide 6.0.3 which will config your Netfinity up to Win2000 Server. I used ServerGuide 7.3.06 to install Windows 2003 Server. The latest version (IBM ServerGuide Setup and Installation CD v7.4.17) is on the support IBM web site:
http://tinyurl.com/5fmv5k
Sep 21, 2007 | IBM Netfinity 5600 8664 Server
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
IBM eserver xSeries 200 8479 Logo
158 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
