Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Problem for Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Same thing happened today
By mkfine on Jun 12, 2009
I loaded the dishwasher last night, put it on normal wash with a 1 hr delay and went to bed. This morning the control panel said clean, but the pot scrubber light was blinking. When I opened the door, the dishes were still dirty and the soap dispenser never opened. I closed the door and hit the normal wash button and then all the buttons, but none of the lights were on and none of the buttons have worked all day. We checked the breaker box and flipped the switch, nothing changed and none of the lights have gone on all day and it completly doesn't work. Any suggestions? By the way, the dishwasher is almost 10 yrs old and we have never had a problem!
Comments:
Jun 12, 2009
- the lights only lit up when the door was closed when it worked. now nothing lights up.
Jun 12, 2009
- Had a repair man come and tell me that I need a new elctronic control which will cost about $350+ tax installed. On a 10 yr old dishwsher, don't think it's worth it. Now looking to buying new d/w. Any suggestions?
Jun 14, 2009
- Thanks!
Solution #1
posted on Jun 12, 2009
Not Rated)
egraber
Rank: Guru
Rating: 89%, 233 votes
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Comments:
Jun 12, 2009
- check your door switch. take the door apart by removeing all the screws make sure you unplug it. look at the microswitches there are little buttons on them when the door is open if you where to read continuity across them they should have no continuity when you close the door or actuate the button you should have continuity. usually just by a visual inspection you can tell if they/it is good or not. if the button goes in and out and you hear a click sound usually means it's ok. but if the button is sunk in and you cannot press it it is bad. check it out and let me know. if this does not work you should have a fuse that sits on your computer board. it has normally either 2 black wires going to it or 2 brown wires going to it. check if there is continuity there if your door switch if fine. please let me know how it goes
Jun 14, 2009
- i would say buy one with less options don't but a Maytag they are **** the touch panels go out in those ALL the time. I would buy one with a machanical dial no touch controls. These usually last longer than the ones with touch panels and electronic controls. GOOD LUCK
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air 24 in. JDB1100AWS
Questions and Unsolved Problems for Jenn-Air 24 in. JDB1100AWS
Do you recommend Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher?
Answer
Answer
My Jenn Air dishwasher has water standing in the bottom after every use model #JDB1111AWS. I'm using... (More)
Answer
Does my dishwasher have a filter that needs cleaning? My dishes are coming out dirty with particles... (More)
Answer
My JDB-5 Jenn-air dishwasher has started making a loud noise shortly before the drying cycle
Answer
We have a Genn Air JDB-5 Dish washer, last night when we turned it on and closed the door, all of a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air 24 in. JDB1100AWS...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
