Question about ASUS P4S800D-X Motherboard
Please help hi good day! My P4-478 pin, asus motherboard,128 of RAM computer keeps on hanging everytime after or while booting up, i can't figure out what causes it. And sometimes it fails for display. Is there a hardware problem, how do i properly fix it? Pls help, thanks! The steps i took were detached and reattached the RAM, CMOS battery if it fails to display to screen. thanks please help
    Champion:
  • 209 Answers
That shows that the ram memory is low, you need to upgrade to at least 256 or 512mb. because everytime you use the internet a there will always a temporary file that saves. you need to maintain your system by atleast amonth disk clean up. but the best is the you need to upgrade your ram memory
Posted on Nov 20, 2007
I have an ASUS P5V800 motherboard. I have been having problems with the computer hanging at random times during start up. Sometimes it hangs before the mem test, sometimes during hard drive detect,...
Have you tried cleaning the connections and as well as the motherboard? Based on my experience, dust, especially moist dust that has build up inside the CPU tower can cause malfunctions. What i usually do is i dismantle the CPU tower and clean the components inside with soft-brissled paint brush like heat sink and fan, motherboard, graphics card, etc. When in come to the RAM i clean the pins with pencil eraser like shown in the image below.
and re-assembling them again. hope this helps
Sep 26, 2009 | ASUS P5V800-MX Motherboard
Hi Could you please recommend a suitable replacement for my Asus P5G01-VM Motherboard, baring in mind that I wish to keep my processor, memory and case etc... Many thanks
Dear Sir,
You can upgrade your computer with now a days motherboard i.e G31 chipset motherboard.It deffinately supports your RAM and Processor. You can buy Asrock,Gigabyte,ECS G31 Chipset Motherboards. I think it helps.
good luck
Aug 08, 2009 | ASUS P5GD1-VM Motherboard
ASUS PSVDC-X Motherboard
Hi there.
Three long beeps means there is a problem with the ram, get a soft clean paintbrush and clean the brass contacts on the ram and also clean the ram slots of dust and then reseat the memory and try to boot the machine again, if it still does not boot then the ram may have to be changed.
Good luck and thanks for using FixYa!!
May 11, 2009 | ASUS P5VDC-X Motherboard
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
A7V 400MX ASUS Mother Board: Problem
i had same thing - was power supply,,,,replaced and all fixed, now boots properly everytime
Mar 15, 2009 | ASUS A7V400-MX Motherboard
Antivirus sofware not supported
maybe the antivirus you are using needs a bit more (ok lots more") RAM to boot in your computer so i will tell you to increase RAM or use NOD32 antivirus
for you computer
have anice day
Feb 19, 2009 | ASUS M2N-MX Motherboard
Loud ring while trying to boot for first time with Asus P5Q3
Hi im josh in cebu phils. may i help you. i got the same problem last week when i bought intel board. the same problem you have a long loud beep in the first boot. it is a video card problem.if you are using video card having 128 mb or below it will beep and may damage the motherboard. but when it is higher 128 like 256 or 512 mb it is good. i solved this problem of mine. i hope the same you too. Good luck
Feb 15, 2009 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Ram when i upgrade 128 sdram to 256 sdram in intel 845glly it shows spd
It is not seieng the ram, try swapping the ram around or leave out the 128MB, just put in 256MB, if no boot then the ram is not compatible or faulty, not all ram sticks work in all motherboards.
Sep 08, 2008 | Intel D845GLLY Motherboard
Need help
hi habiba,
just insert gently to your motherboard, make all other connection well to board, and swicth on.
1). If you hear a long beep, means missing RAM, i.e. either the RAM is not connected properly or your RAM is bad.
2). If you hear just a beep for less than a second, and your computer get started, means your RAM is good....... :))
Thanks
Iqbal
Mar 31, 2008 | AOpen (MX4SGI4DN2PRE) Motherboard
ASUS P4S800D-X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
