I have purchased two remotes ( RCR461) One for a Toshiba and the other for a Samsung. The codes were not included in the packaging. I need some advise on how to code them. The remotes do not have a code search button. HELP!!
Ok, basically this problem has been a big run around for me as well, but i found the manual for the rcr460 is actually the correct manual for this device. all the other ones are complete ****. but to save you all another run around heres how its done.
1. turn on device that needs to be programed into remote, press and hold the device button you wish to code in.
2. when its lit solid press and hold the power button while holding the selected device button as well for three seconds, the selected button will go out but you need to let go when it does you need to let go.
3. proceed to then press the power button over and over and over again until the device turns off.
4. press the stop button to save the code.
5. DONE!
your remote now works.
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
