Question about Hyundai ImageQuest HQL260WR 26 in. HD-Ready LCD Television
No Red PowerLight, but if I unplug and plug back in red light but no green.
I can unplug and plug back in.  Red light comes on but as soon as I press the on button the green light comes on for about two seconds before tv turns off, including red light.
rkitten@earthlink.net
  • 10 more comments
  • oilervic Nov 03, 2007
    No Red PowerLight, but if I unplug and plug back in red light but no green. problem, and notify you when a new solution is offered.
  • beltwaygrrl Nov 12, 2007
    red power light comes on, but as soon as you try to turn on the tv the ggreen light blinks several times, them turns off completely.
  • Anonymous Nov 19, 2007
    THE SAME
  • dondurito Dec 08, 2007
    same thing here, except is always does it at a certain time of day, made me think its timer related.
  • rkitten Jan 10, 2008
    T took our set to a repair and they stated that set needs a new power supply. Power supply cost $200.00. Does anyone know where I can purchase power supply?
  • beltwaygrrl Feb 04, 2008
    Do not try to get a straight answer from the technical support group at Hyundai repair. I had the TV repaired by them less than a year (2006) after my purchase for the same issue-faulty power supply board, and now it failed again in dec. 2007. repeated calls to them are useless. i tried to get a local repair shop to fix it and they are having difficulty getting the part. I will never buy another TV made in China...unfortunately that may not be realistic because everything is made in china.
  • rkitten Feb 12, 2008
    Have not been able to find a power board. Samsung is the manufacturer of the board and Samsung no longer makes. They sent me to Samsung parts and they do not have either. All suppliers on the net that I have spoke with do not stock as manufacturer quit making parts. Guess the best we can do is get some rope and use it as a boat anchor............................... or if someone has found a solution let me know.
    Rkitten@earthlink.net
    956-454-0914
  • andy840 Oct 06, 2008
    I have the exact same problem with my HQL260WR purchased in august 05, so 3 years old (also from manufacture). When powered up green light comes of a couple of seconds then cuts out - phut!
    Any solution other than the trash would be nice...
  • danimation Oct 20, 2008
    SAME PROBLEM HERE. WHEN YOU TURN IT ON THE GREEN LIGHT BLINKS ABOUT 4 OR 5 TIMES... THEN THE TV FLASHES FOR LESS THAN SECOND AND SHUTS OFF... NOT EVEN A RED LIGHT AFTER THAT.
    I tried the blow dryer trick but it didn't work. I'm not sure if I'm doing it right... where exactly do I put the blow dryer? and how long do I hold it there?
  • assuntadesim Oct 23, 2008
    Red stand by light on, when press turn on button on remote control green light flashes then Tv goes off with not power at all. If switch on an off the plug for at least 15 min the Tv comes on. Any Help please the Tv is only 3 years old (Hyundai ImageQuest HQL260WR 26)
  • Anonymous Nov 30, 2008
    The power supply for mine was made by Image Quest, out of California. Contacted the support section and tried to speak with someone that did not want to help. All he said was send an email with part # and serial # and they will respond. Never happened, also had an extended warranty that was not cheap and no help there either.
    So, it has come down to not purchase anything from Tiger Direct and stay away from Korean made electronics.
    Just what I have experienced.
  • mcybarra1 Apr 03, 2009
    I am having the same problem with mine, it just stopped working about few weeks ago. When you unplug and plug back, it acts like it is going to turn of for a few seconds and then turns off. Purchased from TigerDirect in DEC 05.
Just follow these vid instructions. I fixed mine and it works fine now. If you can't do the work contact me @ jericotagl@yahoo.com and we can work something out.
Posted on Apr 06, 2009
It is the 3 capacitors at the top of the power board size 1000uf35w they are £5 for 5 on ebay basic soldering skills un solder the old solder in the new job done even tells you on the main board which way they go in it takes longer to unscrew the set then it doe's to solder the new capacitors in
Posted on Oct 06, 2009
Thanks, esp. to jericotagl for including that link to Falcon204's video. And of course to Falcon204 for preparing and posting the video. I replaced those 3 capacitors and my Hyundai TV is like new again!
Posted on Aug 19, 2012
  • levinedl Aug 19, 2012
Could you describe in more detail what it was you did and what made you try it? I can see why a heat source may be a cold solder of sorts if there is a short on the power board its self, and that makes send,, but what is "play plug"? or just give a few more details,, maybe this is a good start to find somewhat of a solution for this dang tv,, thanks man!
Posted on Sep 22, 2008
I use a blow dryer to heat up around the power switch and play plug and uplug the power cord for like a few mins and my tv turn on.now i think i have to leave my tv on until it drop dead.
I took our set in to a TV repair and they stated that Power Supply had to be replaced. Supply alone is $200.00. Does anyone know where we can get parts?
Posted on Jan 10, 2008
What can i do to fix this
it does that sometimes just unplug the system and it should be working just fine
Jul 29, 2009 | Microsoft Xbox 360 Console
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Blinking Red Light
unplug your printer
try to move the ink case manually.
if you could remove the ink cartridge, then clean the contacts both on the cartridge and case. return the cartridges then move the case to its original location
plug
Nov 06, 2008 | HP PhotoSmart 7660 InkJet Printer
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
Jan 05, 2008 | Televison & Video
Flashing green and red light
Sounds like a power suppply problem. Not something that the novice can repair besides trying the usual unplugging and plugging back in.
Apr 18, 2007 | Syntax Olevia 50" Rear Projection...
Hyundai ImageQuest HQL260WR 26 in. HD-Ready LCD Television Logo
598 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
