Question about EverFocus EDSR1600 16 CHANNEL 160GB DIGITAL VIDEO RECORDER with AUDIO&REMOTE OBSERVATION
Camara can't get in from outside to my camaras
How get backup of HDD dvr EDSR1600?
Posted on Feb 13, 2008
Enciende y aparece reinicie camara error de objetivo
tengo problema con mi camara...!!
la enciendo y m sale error de objetivo reiniciar camara... la camara se apagara autmaticameente
Aug 30, 2011 | Canon PowerShot A495 Digital Camera
The proble is that my camara has the lens outside, when I turn on my camara appear a message that say lens error m627-31 y then the camara turn off
the motor that drives the lens must be damaged, u need to take it to the local service center to get the camera repaired.
Apr 14, 2010 | HP PhotoSmart M627 Digital Camera
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil pmgibs1@verizon.net
Feb 20, 2010 | Dell Latitude D410 Notebook
Z710..after a short time..warning says ''high camara temperature'' and shuts down
That means that your camera will shut down immediately so it doesn't burn out. Are you in an environment where outside temps are super hot, or leaving the camera in the sun or vehicle too long?
It can also happen if the camera is subjected to different dramatic temperature changes, like taking pics in central air conditioning and then go outside in the extreme heat.
Oct 24, 2009 | Kodak EasyShare Z710 Digital Camera
On my HP 537 camara my daughter dropped it now the switch that makes the camara go to view pictures or take movies will not work, it just slides back and forth? Is there a way I can open it and fix the...
If you can take things apart without damaging things...then it may be possible to fix. I have had mine apart several times, and the slider on the outside, switches a mini micro slider inside. It has to be lined up with the tabs...dropping it may have caused it to jump the slots.
Mar 09, 2009 | HP Photosmart M537 Digital Camera
Flash
I gave the lense part of the camara a moderate slap, and the camara has worked fine since. looks like a lot of people have the same problem. Most of the people call it black screen problem. the shutter gets stuck. Tap it a few times on the side of the lense part of the camara moving it from bright to dark objects back and forth.
good luck.
Aug 18, 2008 | Nikon Coolpix S4 Digital Camera
Water damege
That depens if the fog is inside or outside, outside it usually dries faster than inside. You are advised to let it dry at least another 24 hours , if the lens is still foggy after that , thab you must go to a repair shop to let it be cleaned.
May 05, 2008 | Kodak EasyShare C613 Digital Camera
I dropped my camara and lens is stuck on the outside
Dear pat123456,
If you dropped your camera and now the lens won't retract back into the camera, and it won't power on it sounds like you have internal damage. You need to have it looked at by an authorized service technician.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 07, 2008 | HP Photosmart M425 Digital Camera
Microsoft LifeCam NX-6000 and Yahoo messager
you'll need the drivers for that Yahoo IM from your webcam folks. it's a bit persnickity
Feb 16, 2008 | Microsoft LifeCam NX-6000 Webcam
Televison & Video Logo
133 people viewed this question
Top EverFocus Televison & Video Experts
Marvin
Marvin
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
